Old 08-31-2007, 03:54 PM   #1
phill_54321
phill_54321 is on a distinguished road
Default Mass Air flow sensor
Does anyone know if you can use carb cleaner to clean the Mass air flow sensor?
phill_54321 is offline   Reply With Quote
Old 08-31-2007, 04:08 PM   #2
Syris
Syris is on a distinguished road
Why would you be thinking about doing this?
Syris is offline   Reply With Quote
Old 08-31-2007, 04:10 PM   #3
phill_54321
the people at auto zone said that if there is no check engine light then the mass air flow sensor is probably not bad just clogged. Two different employees said that the carb cleaner should work
Old 08-31-2007, 06:24 PM   #4
twerb089
twerb089's Avatar
twerb089 is on a distinguished road
is it a gte or ge? GTE's have a karmen vortex maf and you can disassemble it and wipe it down and it should be fine
1989 supra turbo automatic soon to become a manual
K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back
NA intake cam, shimmed actuator
no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior.
gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms
twerb089 is offline   Reply With Quote
Old 09-01-2007, 05:40 PM   #5
mrnickleye
mrnickleye's Avatar
Angry WE don't have Carburetors
Those 'zone' guys are thinking of the other MAF that uses a wire or 2 inside. CRC makes a MAF sensor spray just for cleaning it. NEVER use carb spray. The word CARB should pop out at you.
Carb spray is VERY strong, and can screw up plastics.
BRAKE spray cleaner would be OK.
Old 07-04-2011, 04:42 PM   #6
RedAstig
RedAstig is on a distinguished road
Default Idk
I just clean my Mass air flow sensor with CRC sensor cleaner, then after that my car wont run the same way, I dont know what happen, I remember I hit it accidentally while taking it off then spary a lot of cleaner, you think I mess it up? i just order a good one from ebay and waiting for it to come. My Supra is 1988 MK3 7m-GTE, any advice guys? I appreciate it.
p.s.
When I press the gas faster it will not boost and I have to press it lightly. I cant press the gas faster coz the car will slow down, I feel like no much gas going to engine.
Please help
RedAstig is offline   Reply With Quote
Old 07-04-2011, 05:27 PM   #7
btwilson86
Super Moderator
btwilson86's Avatar
The short answer, yes. You did ruin it. The CRC can specifically says to not use on KVAFM style air flow meters, which is what the 7mgte uses.
Hopefully the one on ebay you bought is actually good.
Old 07-04-2011, 10:22 PM   #8
907mge
907mge's Avatar
Yep, I looked again on my can of crc maf cleaner and it specifically says do not use on a KVAFM and it lists the supra as the first example. I guess it pays to follow instructions.
Old 07-04-2011, 11:36 PM   #9
RedAstig
Thank you Guys, learn my lesson...I appreciate your time to answer. Just in a hurry when I got my first mk3 after I sold my mk4 then I did it with mk4 but ok, and then immediately spray it on mk3 without really reading it :-) thanks again guys.
Old 07-04-2011, 11:38 PM   #10
RedAstig
sorry bout my english lol
Mass Air Flow Sensor? SuperSpartan Non-Generation Specific Questions 0 05-03-2008 07:51 AM
My Air Flow Sensor SuperSpartan Non-Generation Specific Questions 0 05-01-2008 08:45 PM
550 injector & lexus air flow troubles o2 sensor? night-rider MKIII Supra 1 09-03-2007 08:52 AM
