Old 08-26-2007, 10:54 PM   #1
supraman121
Default Got to be info here we can use
http://www.suprastore.com/bolost2notot.html
This is the setup for a na-t mk4 supra its a 525hp setup on the stock mk4 internals.
Here we go non-turbo Supra owners! Turbo power for your non-turbo Supra from Boost Logic. Fits 1993-1998 Supra Non-Turbos (both automatic and manual trans).
Approximate power capability 525hp.
This kit contains everything you need to convert your Non Turbo MKIV Supra or SC300 into a turbo charged sleeper. Here is the list of parts included.
Boost Logic 321SS Tubular Manifold 1 5/8” Tubing and 1/2” Thick 321SS Flanges
(Turbo’s with a 4” inlet clears the distributor.
Manifold fits a turbo up to a T76)
Boost Logic Spec T4 Turbo
HKS 40mm Wastegate
3” SS304 Polished Downpipe w/ Flex Joint
3” SS304 Polished Midpipe
SS304 Polished Dump Tube
3” Polished Aluminum Intake Pipe
Boost Logic Front Mount Intercooler (FMIC) Kit
2 ?” Polished Aluminum IC piping
4 Ply Silicone Hose Connectors
Stainless Steel Hose Clamps
Boost Logic NA-T SS Braided Oil Feed and Return Kit w/
Aeroquip fittings
3” K&N Filter
K&N Breather for PCV Valve
Walbro GSS341 255HP Fuel Pump w/ Install Kit
Stage II Upgrades
Boost Logic 2.5mm Head Gasket
440CC Injectors x 6 (fits in the stock rail)
Injector Piggy Tails x 6
All necessary clamps and bolts for installation
Note. As with all turbo conversion kits installation should be performed by those familiar with turbocharged engines and tuning. Serious engine damage can occur with improper installation or tuning. Consult an expert.
Ok well there has to be something we can learn from this so us non-turbo mk3 owners can get the same amount of hp i know there not the same engines but the internals should be of about the same quality, and we should be able to find the same things, for the 7mgte/7mge motors plz help us non-turbo guys get turbo.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 08-28-2007, 01:56 AM   #2
kwnate
SP58GT
First learn how an engine works, then learn how a turbocharger works and finally learn what they do together. You need to do alot more research before you start your project. When I say research I don't mean asking 20 million questions. Do some reading then ask questions.
Nate
Old 08-28-2007, 05:13 AM   #3
supraman121
Well i know im along way away from starting my project im put a new na engine in my car, i have a general consept on how the engine works and how the turbo works with the engine, but everyone i talk to says its a waste of time to turbo charge an na engine cause you cant get much power out of it, well the kit i listed isnt for my engine but that engine isnt forged either and they can get 400hp out of it with 8psi boost why cant we do the same thing with the 7mge's? If you can do it with one you should be able to do it to the other one. A forum is for asking question tho, but to your wishes i will research some more, maybe you couldnt point me in the right direction i just read the how stuff works on turbos and its all just kind of confusing like i said i have the general consept.
K&N Air Filter
Old 08-28-2007, 12:35 PM   #4
f00g00
The 2JZGE has about 25 more ponies than our motor, the block size is different so the exhaust manifold from that kit couldn't be used (or I'd allready have gotten a set of stainless steel headers from the lexus 2JZ for my car), The fuel injection system is different, you would probably have to run the MAFT pro setup to compare to the 2JZ system because it is either speed density or map sensor no AFM on them.
They also include a metal head gasket with the kit which won't fit on ours but we can go metal but the work involved with lapping the head and prepping the block is very labor intensive.
You could go 1J or 7MGTE for the price of that kit and probably be at that HP or more.
Old 08-29-2007, 04:49 AM   #5
supraman121
Well i didnt mean use that stuff i ment we should have some of the same things for our cars or the equivelant of.
K&N Air Filter
Tranny ? Need Info! SilverBullet05 Non-Generation Specific Questions 0 07-07-2008 09:45 PM
info on 1984 supra 84cuddy MKII Supra 1 11-22-2007 11:00 AM
Info on MkIII Supra Nic MKIII Supra 2 03-15-2007 11:27 PM
Emissions Test Info in "Your" Area/State mrnickleye Off Topic Forum 9 05-01-2006 01:11 AM
89 NA => Turbo SWAP INFO akadiablo MKIII Supra 0 12-09-2005 06:21 AM
