Old 08-25-2007, 02:43 AM   #1
justin1642
justin1642's Avatar
Default how to stop belt squeak
ok i had an electric fan then when it died i put the normal fan on and ever since then everytime i start the car the belt squeaks and if i don't let the car sit for at least 5-10 min then when i accelerate the belt squeaks still but when its finaly warm its fine no squeaking at all. its just annoying and i want to know how to get rid of the damn squeak. did i tighten the fan down too much?
Old 08-25-2007, 03:56 AM   #2
A new belt, properly tightened should not squeel.
An over-tightened belt usually does not squeel, but will prematurely wear out the bearings in the components driven.
Old 08-25-2007, 05:12 AM   #3
justin1642
justin1642's Avatar
well i didn't touch the belt i just bolted the fan onto the pulley and since then it made the belt squeak. so i don't know why it started to squeak since then.
Old 08-25-2007, 05:44 AM   #4
oowee623
oowee623's Avatar
have you tried belt lube
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
Old 08-25-2007, 06:24 AM   #5
f00g00
The fan with the clutch would load the belt a bit more which might cause it to squeal. You can try belt dressing or get a new belt.
Did you get any power difference by running an electric fan?
Old 08-25-2007, 06:32 AM   #6
justin1642
justin1642's Avatar
honestly i couldn't tell if i did it was very small but i only had one fan i didn't have the dual electralite ones so i don't know if those make a difference. thanks for the advice.
Alternator belt removal and installation! ~*B Magical*~ MKIII Supra 11 03-13-2008 07:27 PM
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
Timing belt is escaping! go.stfu MKIII Supra 7 07-14-2007 10:38 PM
Power steering belt jumping off SupraDupra Non-Generation Specific Questions 1 11-22-2006 11:15 PM
Timing Belt Change, Do It at Home mrnickleye Supra FAQ 2 09-19-2006 06:24 AM
