Old 08-24-2007, 05:52 PM   #1
igosaur
igosaur's Avatar
igosaur is on a distinguished road
Default Oil Change
Hi
I've read several posts on the type of oil that should be used but must confess am still a bit unsure.
I have a 7M GE 3.0i Auto that has done 123000 miles.
At the moment I am using a part synthetic 10W40 oil. I'm about to do an oil change and am wondering if this is ok or would you recommend something else?
Basically, what do you have in yours?
igosaur is offline   Reply With Quote
Old 08-24-2007, 11:41 PM   #2
supraman121
Originally Posted by igosaur
Hi
I use havoline 10w 30 with deposit sheild, 10w 30 is the type of oil or thickness i think the factory put in them, but i would use a full synthetic 10w 30 unless your burning it or leaking it, castrol should be good, Im still a havoline fan my self but my brother swears he can tell a power difference with the 10w 30 castrol synthetic.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 08-25-2007, 04:05 AM   #3
It has been reported by several sources that switching to a synthetic oil after having used dyno oil for 100k miles is not a wise thing to do.
Primarily due to the syn oil cleaning away the varnish and deposits that build up around the seals, thus causing leaks to develop.
A name brand 10w-30 or 10w-40 would be fine.
PS: Your brother is overly sensitive.
Old 08-25-2007, 02:03 PM   #4
supramacist
supramacist's Avatar
I run castrol 10w 40.
The car likes the 10w 40 over the 30.
So that's what I feed it.
Hybrid oils half this and half the otherr are ass in my opinion.
If you want to run synthetic. You should buy a NEW car and start it on that immediately.
Because, yes it will either leak or smoke. You don't change horses midstream.
And that's really what you are doing with 123kish on the engine.
Stick with conventional and don't mix oils either.
Old 08-25-2007, 03:57 PM   #5
oowee623
oowee623's Avatar
is the toyota genuine 10w-30 oil any good? thats what ive been using
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
Old 08-25-2007, 04:17 PM   #6
supramacist
I have seen that oil.
I have never used it so I can't critique it.
I have always been seved well by Castrol and are hesitant to change.
Unless I get something new.
If I was going to run synthetic it would be Mobile 1 full synth.
10w30 and 10w40 for the sup and 30 in everything else unless specified.
Change the climate cntrl color? XtreeX MKIII Supra 6 05-10-2008 01:54 PM
Speedo is out, what do I change? linuxgurupodboy Non-Generation Specific Questions 0 05-15-2007 12:07 PM
my mkiv supra wont start after engine change HELP!! gkhawk MKIV Supra 1 08-18-2006 12:40 PM
spark plug change supfoo514 MKIII Supra 4 06-30-2006 07:41 AM
Should I STILL change head gasket?? lifesnotfair MKIII Supra 7 01-13-2006 01:08 AM
