Old 08-23-2007, 06:02 PM   #1
redmaro
Default MSD fuel pump?
I went to a performance shop and the have this a MSD fuel pump for $149 its supposably a high volume fuel pump what kind of benefits should this pump give to my car??? car is stock.
Or should I go with a Walbro fuel pump for $100 or a Denso fuel pump for $120.
MK3, Auto, Turbo.
Old 08-24-2007, 12:29 AM   #2
supraman121
Alot of Poeple go with the Walbro Fuel pump, so that is what i would go with, dont guy buy what the shops says there trying to sell what is most expensive, but alot of poeple on the forums that have a turbo car go with the walbro and you save 50 bucks what could be better?
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 08-24-2007, 01:18 AM   #3
supramacist
supramacist's Avatar
Dude I went with the walbro and it is a mammoth.
I wouldn't think the MSD any better than the walbro. I am sure it would not disappoint. But you may be paying a bit more for the brand.
Old 08-24-2007, 01:25 AM   #4
redmaro
Yeah I was thinking of going with the walbro fuel pump. All my fuel system is stock anyways, and Im only planning on running 10psi of boost after I get my new fuel pump. Thanks guys.
MK3, Auto, Turbo.
Old 08-24-2007, 02:08 PM   #5
Supra2NR
Supra2NR's Avatar
u can run the 10 psi without the walbro
but the walbro is pretty good, im gonna use a twin 255lph setup on my car
and put relay for both of them and a switch for each of them
so i can have to setups depending the drivin g condition
but i have to set two fuel maps too, jus throwing it out there
Old 08-24-2007, 03:39 PM   #6
redmaro
My current fuel pump isnt real good right now, but yeah im going with the walbro.
Take pics of your engine bay, post them in your build thread. I wanna see.
MK3, Auto, Turbo.
Old 08-24-2007, 04:09 PM   #7
supramacist
The walbro and the rebuild makes my ride sound like a growling grumbling bear.
It's much more intense and aggresive now.
I just have to get the ecu solved. Glad I could help.
fuel pump mounting bracket GremlinMKIII MKIII Supra 4 09-06-2007 07:08 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Fuel pump hanger for 87 supra non turbo rlipp69 Non-Generation Specific Questions 0 06-16-2007 03:23 PM
Fuel Pump or what? Drack57 MKII Supra 7 11-28-2005 07:33 PM
Fuel Pump Hanger Assembly selbyjr MKII Supra 0 10-24-2005 09:41 PM
