Old 08-21-2007, 09:13 AM   #1
bluebullet89
bluebullet89 is on a distinguished road
Cool Missing 1jz Parts
HEY WHEN I GOT MY FRONT CLIP AND SWAPED IN EVERYTHING THEY SEEMED TO HAVE MISSED A PART LOL... THESE ARE SOME PICS. NOW THE SUPRA IS ACTING A LITTLE ODD WARMS UP WHEN I GET IT ON THE FREEWAY GOING ABOUT 75. BUT DRIVING ALL AROUND TOWN AND PARKED SHE STAYS COOL. SO ANY THOUGHTS TO WHAT MIGHT BE GOING ON.. DOESNT PULL ANY WARM AIR THROUGH THE VENTS. LET ME KNOW IF THIS PART COULD BE THE PROBLEM AND WHERE I MAY FIND IT.. WOULD BE GREATLY APPRECIATED... IF ANY ONE HAS OTHER QUESTIONS FEEL FREE TO ASK.
LINK TO MY CAR
RANKED 17 OUT OF 348
http://www.cardomain.com/ride/386127
Name:	part i need.JPG
ID:	1024   Click image for larger version
Name:	part needed.JPG
bluebullet89 is offline   Reply With Quote
Old 08-21-2007, 10:06 AM   #2
supradaddy0803
supradaddy0803's Avatar
That is the factory Blow off valve. Its all there all the vaccum piping is metal and underneath. As for needing it I have plugged mine off and gotten a aftermarket one because the factory ones are known to leak. As for the warm up how much warmer is it getting mine stays a constant through all driveing ranges and are you still running the stock hydro fan or a electric?
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 08-21-2007, 10:34 AM   #3
bluebullet89
i was wondering if it was the BOV. it'll warm up all the way to about 1/4 inch beneath the H mark so i didnt wanna hurt anything so i would always back off when that happened.. its definitly not constant. it heats up on the freeway. i was thinking possibility with the turbos.. constantly spooling at a certain RPM and causing heat. cause when i coast.. the temp drops. sitting the temp drops of course the turbos in those cases arent spooling.. i have the stock hydro fan cause suposably they push more air.
Old 08-21-2007, 03:02 PM   #4
pato
pato is on a distinguished road
have u checked the thermostat ?
pato is offline   Reply With Quote
Old 08-21-2007, 07:38 PM   #5
supradaddy0803
The turbos being oil cooled really wouldnt heat it up that quick and cool off that quick. Did you use the radiator temp sensor or did you wire it out of the system. Mine isnt connected and the fan runs full blast all the time. other than that check to see if your thermostat is working properly and yes I know it sucks to get to. Also try disconnecting the plug for the temp sensor in the radiator and run it down the road then if it doesnt do it then just leave it disconnected.
1JZGTE swap
JZA70 Front end mod
Old 08-22-2007, 02:28 AM   #6
pato
if udisconnect the temp sensor from your radiator, your thermo fan should go nuts
worth a try to just check it
Old 08-22-2007, 11:33 AM   #7
supradaddy0803
I have had that sensor diconnected since I got the motor in the car and it was broke and it works fine just runs full blast all the time.
1JZGTE swap
JZA70 Front end mod
87 MkIII vs 89MkIII -- parts interchange willblock MKIII Supra 5 07-24-2016 06:27 PM
