Old 08-20-2007, 11:57 PM   #1
rcboricua07
rcboricua07 is on a distinguished road
Default Stayin on and Idling????
ok guys i got a problem...I start my car and it idles really low sometimes to the point where the car shuts off its really rough when it idles and doesn't last long before it shuts off...if u rev it and then stop it automatically shuts off...this is gettin old...does anyone whose been workin with this car for a while no wat might be goin on...i need some help and dont know what to do...
rcboricua07 is offline   Reply With Quote
Old 08-21-2007, 12:09 AM   #2
supradaddy0803
supradaddy0803's Avatar
Check your ignition timing sounds like it is a bit off. If not that I would check the TPS ( throttle postion sensor) to make sure it is rigged right. But I am thinking it is your timing.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 08-21-2007, 04:55 AM   #3
You could also try checking your Vacuum lines... I had a couple routed to the wrong place (oops) and a cracked one, and it was causing a very low, sporatice idle that would occasionally stall the engine. Also, if I revved it up real quick then let off the gas almost always it would immediately stall.
Old 08-21-2007, 05:01 AM   #4
redmaro
Do a diagnostic, check the faqs section and look for the thread on doinga diagnostic.
MK3, Auto, Turbo.
Old 08-21-2007, 08:02 AM   #5
Supra2NR
Supra2NR's Avatar
could be a reallt bad vacuum leak,
but when you said it revs, how high can it rev
does it rev to only 2000-2500 rpm?
could be the AFM too
Old 08-21-2007, 09:13 AM   #6
rcboricua07
yea actually it only revved up as high as 2000 and maybe just a little ova...
Old 08-21-2007, 04:04 PM   #7
Supra2NR
Supra2NR's Avatar
go check the wires on the afm, sometimes it gets pretty brittle and when the engine, moves or you hit a bump, it can break
thats what happend to me, so try looking at that one and let us know what happens
Idling Problem! Dejvid1785 MKIII Supra 22 10-05-2007 12:46 AM
1986.5 Idling at high RPMS Sasukevh MKIII Supra 2 06-14-2007 04:56 AM
Low idling at stop Chomper MKIV Supra 5 02-13-2007 10:45 AM
Car Keeps On Idling Wierd.... 2JZEFINI-17 MKIII Supra 5 01-29-2007 11:54 PM
93 supra is idling high kellyb Non-Generation Specific Questions 2 04-02-2005 02:06 PM
