Old 08-20-2007, 10:12 PM   #1
dannydavi
dannydavi's Avatar
Default Coolant Hoses?
hey all i had another bad experience with cracked hose this weekend and all my water left my vehicle, so i cut the hose shorter once i found it, and re-tightened the clamp and made a fix... but now i would like to replace all the hoses so this doesnt happen to me again. the one that broke on me this weekend went from head to what it seems is the firewall, i think, i'd have to go look again, anyways i was wondering if that hose had a certain name, also where to get coolant hose kit. Wouldnt mind them looking like the new guys lexus steel mesh kit either, thanks for any info
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 08-22-2007, 08:16 PM   #2
dannydavi
dannydavi's Avatar
alright guys i found some sleeves to cover hoses, and found steel braided fuel lines, but not finding any steel braided radiator hoses or heater hoses etc. Looking to upgrade the cooling system cause dont like when my hoses go out on me while im driving so any help is appreciated, thanks. Also will get pic on here of hose that broke on me this weekend, thanks in advance.
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 08-22-2007, 08:42 PM   #3
dannydavi
dannydavi's Avatar
the dark black one going across the middle of pic heading down after the left valve cover is the one that broke on me, does it have a name?
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 08-22-2007, 08:46 PM   #4
supradaddy0803
supradaddy0803's Avatar
I think it is called the heater core feed hose because that is what it does you could always just buy some 1/2 inch hose and make a new one. Just be kind of giving on the corner and it should be fine.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 08-22-2007, 09:10 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
Heater Water Outlet Hose Toyota part # 87245-24190 for a UK RHD
I would guess it would be the same for a US LHD
Old 08-22-2007, 11:28 PM   #6
dannydavi
dannydavi's Avatar
thanks for the responses guys, i had thought about just getting same size hose but it had some drastic curves so thought it might have specific part i can replace with, so thanks for the info on the part number, will be replacing soon.
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 08-23-2007, 12:35 AM   #7
west_side_supra
west_side_supra's Avatar
ummm goto www.summitracing.com
that is were i got my steel braided kit for like 25$
they also sell the metal bends like 45o and 90o bends so that way you wont kink the hose if you goto your auto shop and just buy new hose. plus it looks pretty
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 08-23-2007, 12:37 AM   #8
west_side_supra
search results
thats all the stuff for hoses for summit
fidenza cam gears
Old 08-23-2007, 07:20 PM   #9
dannydavi
dannydavi's Avatar
so apparently it's $50 for that hose, with the 20% discount it got down to $42... so i said fuck all that shit. what else can i do... get the same size hose and get bends for it?
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 08-24-2007, 02:10 AM   #10
I just used a piece of straight GATES hose (top quality)from parts store and 'bowed' it over. No kinks, plenty of clearance, and looks OK.
You could get straight hose and come up off engine to a 90* elbow, then hose over to the heater fitting.
MK3 supra Hose Techniques silicon hoses Micahwc Shops & Part Reviews 8 12-09-2012 09:03 PM
Can anybody show me help me with coolant hoses jesse_c91 Non-Generation Specific Questions 0 06-10-2008 03:19 AM
coolant everywhere TITAN DOHC V8 MKIII Supra 0 09-09-2007 05:45 AM
