Old 08-04-2007, 12:39 AM   #1
targaiii
targaiii is on a distinguished road
Default Oil pressure trouble
So I blew my turbo last year and just got it back on the car. Now I'm afraid to drive it because the oil pressure just doesn't look right. I'm at 40 lbs. cold and 20 or less warm. I've looked in the manuals, but no help there. I swear it was in the 80 lbs. range when I first drove it. Can anyone tell me what thier normal operating oil pressure is cold and at temp?
targaiii is offline   Reply With Quote
Old 08-04-2007, 01:01 AM   #2
twerb089
twerb089's Avatar
twerb089 is on a distinguished road
no thats right
1989 supra turbo automatic soon to become a manual
K&N, megan dp, gutted cat, 2 1/2" magnaflow cat back
NA intake cam, shimmed actuator
no A/C or P/S, therefore no ac condensor, compressor and no ps pump or resivior.
gutted interior, 4 tweeters, 2 kicker 12"s powered by an MTX 400W 350rms and an audiobahn 400W 300rms
twerb089 is offline   Reply With Quote
Old 08-04-2007, 01:39 AM   #3
abhattan
abhattan's Avatar
abhattan is on a distinguished road
He's right, that's right
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Soon to be rebuilt (All to some extent)
abhattan is offline   Reply With Quote
Old 08-04-2007, 01:40 AM   #4
yotaracer23
yotaracer23 is on a distinguished road
same here....40 lbs cold and 20lbs hot ...... if that is a problem i would like to know myself.
yotaracer23 is offline   Reply With Quote
Old 08-06-2007, 12:46 PM   #5
ddmcse
ddmcse's Avatar
Cool
different oil grades will affect the oil pressure
using the incorrect oil filter will change the pressure . different size filters will fit on the supra
make sure you have the right one
engine rpm will also change the pressure
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 08-15-2007, 09:02 PM   #6
targaiii
Thanks for the info guys, very helpful. I found oil leaking from the new gasket between the supply and return line and the turbo itself. I didn't notice it at first, I just hope i caught it in time and didn't starve the turbo for oil. Good way to F- up a new rebuild, huh? Thank you to everyone for their input.
7MGE oil pressure Arne (Denmark) MKIII Supra 14 07-31-2009 10:07 PM
Oil Pressure Sender!? spudz29212MKIII MKIII Supra 8 05-06-2008 01:41 PM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Tire pressure? dannydavi Non-Generation Specific Questions 11 08-16-2007 06:03 AM
oil pressure gauge problem.... SCRAMJET MKIII Supra 0 03-21-2006 06:33 AM
