Old 08-03-2007, 12:04 AM   #1
D_Train
Default light on dash that tells you a light is out
That light is on. I replaced my brake light that was out, but the light will not go off. any tips?
Old 08-03-2007, 01:15 AM   #2
j3pz
check the lil yellow box back under the taillight, they are known to cause this problem
Old 08-03-2007, 03:22 PM   #3
D_Train
What do you mean "check"?
Old 08-03-2007, 06:18 PM   #4
SupraDupra
SupraDupra's Avatar
The little yellow box is connected to the harness that powers your tailights. Moisture gets in there and messes it up. Mine is bad too ,but as long as the tailights keep working I'm ignoring the problem. Not sure where to get the replacement ,but if you pop the access panel off from behind the drivers side light you should see it in there.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 08-03-2007, 09:56 PM   #5
D_Train
Yah. Its wierd tho, the light doesn't go on until I press the brakes....
Old 08-03-2007, 10:07 PM   #6
supraman121
Did you turn on your headlights and see if your tail lights light up... my brake lights would work when i hit the brakes but when my headlights were on they didnt iluminate and my "yellow" box had burnt out and was causing this i had to buy a new one from toyota for 200 bucks.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 08-03-2007, 11:36 PM   #7
D_Train
I
I think yes but I'll double check.
Old 08-04-2007, 05:10 PM   #8
j3pz
not sure how to "check". i meant find a working one on egay or a junk yard and try that, as it is a very common problem
codes - no light on dash ?? eggybread MKIII Supra 0 12-07-2008 10:33 PM
orange/yellow light on far left of dash (aka: The Birdcage, Carousel, Old Radiator) suprra_girl MKIII FAQ 5 09-20-2007 07:32 PM
dash light SAM MKII Supra 5 04-09-2006 03:50 AM
