Old 07-26-2007, 08:25 AM   #1
andrew777
andrew777 is on a distinguished road
Default 87 Supra Turbo
Hi guys, im looking at getting an 87 Supra turbo, and had a few questions.
Firstly, the one im looking at is an 87, silver, 140,000ks lowered, stereo, alarm, turbo timer, full exhaust. Is $7000 a good price for it?
Also, i was won=dering what performance is like in terms of acceleration.
Ive never had any experience with a turbo supra, but have had experience with other cars, so if you could tell me how it would compare to the following cars that would be great:
BA Falcon manual
R32 skyline gtst
93 Celica GT4
VS commodore 6 cyl
Finally, theres no problem with the gasket at the moment, but how much would it cost to upgrade to a metal gasket (i know the head needs machining) (oh and cost includes labour cause i cant do it myself).
Thanks a lot.
andrew777 is offline   Reply With Quote
Old 07-26-2007, 08:36 AM   #2
west_side_supra
west_side_supra's Avatar
performance with acceleration is the supras best feature. they are quick even stock. dont know how it compares to them other cars. but the HG im about to undergo soon
HKS MHG $301.10
machine 200$+ <its all a matter of the shop and what options you choose to do.
ARP studs + Nuts $134.29
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 07-26-2007, 08:41 AM   #3
andrew777
Yeah will i wont be modifying, mainly due to lack of time and knowledge (and funds lol). So itll be pretty quick stock? How will it compare to the cars above?
Old 07-26-2007, 08:44 AM   #4
west_side_supra
i wouldnt doubt it could beat a celica but its not everyday i drive a skyline
fidenza cam gears
Old 07-26-2007, 08:50 AM   #5
andrew777
couldnt beat a turbo celica gt4? Is it cause the celica is lighter or sumthin?
Old 07-26-2007, 09:03 AM   #6
west_side_supra
i really dont know, the way is see it is power to weight will give you most of your answer. the DMV said that my supra weights 3970lbs and i have only added 2 12" subs. i dont know what the stock HP is on a turbo supra. but if it has an intake and full exhaust it may have an extra 50-70hp. then shimming the wastegate to get about 10-11lbs of boost instead of 6.5lbs that will give you a tad bit more power. then your set.
i mean i have
lightweight flywheel
6 puck clutch
shimmed wastegate
greddy rs BOV
3 inch turbo back exhaust - no cats
custom 2.5inch hardpipes upper IC
and it stays up with an STI and im still running the stock airbox
fidenza cam gears
Old 07-26-2007, 09:04 AM   #7
west_side_supra
and ill tell you now the exhaust and shimming of the wastegate was the best things i did for that car, its power that will open your mouth for about 3 weeks till you get use to it and you want more and more.
fidenza cam gears
Old 07-26-2007, 09:07 AM   #8
west_side_supra
when i bought mine it came with 160k miles, all stock, turbo, silver, and its also an 87 and i picked it up for 3500$. but take a look at my myspace pics of it.
myspace pics
fidenza cam gears
Old 07-26-2007, 09:27 AM   #9
andrew777
hmmm, link isnt working. just takes me to myspace home page.
what does shimming the wastegate mean?
Old 07-26-2007, 02:42 PM   #10
Supra2NR
Supra2NR's Avatar
putting spacers (washers) in between the wastegate bolts
basically a poorman's boost controller is what they called it
