Old 07-26-2007, 12:18 AM   #1
zuni
zuni's Avatar
zuni is on a distinguished road
Arrow Tuner Question
For some reason i think im going the wrong direction with my supra. So i figured id see what all of you had to say on this. What would you recomend the first 10 upgrades on a supra be in order from the first to the 10th thing. on a somewhat stock 7mgte turbo.
zuni is offline   Reply With Quote
Old 07-26-2007, 12:26 AM   #2
dannydavi
dannydavi's Avatar
I dont know to much bout these things, but cars in general and what i would like to do with mine if only it wasnt my daily driver is as follows. only listed top 5. some other things might include boost controller, larger turbo, larger injectors, intercooler things like that, but i havent dont to much research on those things cause mine is N/A
1. suspension
2. intake
3. exhaust
4. brake system
5. weight reduction
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 07-26-2007, 12:30 AM   #3
dcrusupra
dcrusupra's Avatar
1. Make sure the engine is working properly
2. Intake
3. Exhaust
4. Fuel
5. Suspension
6. Brakes
7. Better/Wider Wheels/Tires
8. Bigger Turbo
9. Bigger Intercooler
10. Aluminum or Stainless Steel Intercooler Piping
11. Standalone
8-11 should be all at the same time. And for number 1, do a compression test. If any of them are under 120 psi or more than 15 psi apart, it's time for a rebuild. I left them vague purposely because everyone has different goals for their car.
New Rebuild
My CarDomain
Old 07-26-2007, 01:01 AM   #4
88Tsupra
1. fix the headgasket/make sure its all proper
2.intake/new plugs&wire
3.exhuast and Downpipe
4.lexus AFM/550cc injectors/walbro 255phl fuel pump
5.brakes/rotors..gotta b able to stop
6.suspension
7.new clutch/flywheel..gotta get it rdy
8.wider rims and way better tires dont go CHEAP!!!
9.
build up the bottem end now...new pistons/rings rod and crank
10.bigger intercooler 3inch hard pipe/new BOV..gotta love the sound
11.bigger turbo/wastegate
12.standalone ecu
13..driveshaft wouldnt hurt
14.bigger injectors now..to handle the bigger turbo
as for electronics
1.boost gauge/
boost controller..for when u boost over 8psi
2.fuel pressure/vaccum
3.temp
i forgot what else though
feel free to change or add to it
88turbo targa-white
original Pin Stripe
NGK plug and wires
HID conversion head lights
Tial BOV
BIC DDP
Old 07-26-2007, 06:35 PM   #5
zuni
zuni's Avatar
Arrow
Well with my car i wanna keep it a sleeper. however i am gonna have it lowered about 2in. i am also shaving the body. getting rid of the door handles as well as the molding indent that goes around the car. my interior which i am working on right now is gonna be black and a dark red. the interior will have a few more gauges, boost controller, turbo timer. things i need basically. and then i want it to be a fast street car not nessessarily a drag car but i perfer driving on the highways racing from one city to another. so i need it to be good on high end pickup as well as top end speed. so basically i want it nice a fast. sleeper that looks pleasing to the eye but not to much that says "hey i might or might not be fast" if that makes any sence.
And quick question. what is and how do you preform a pressure test?
Old 07-27-2007, 05:57 AM   #6
88Tsupra
the supra has more top end power so you might be fine with that..
but if your going to try and race from one city to another your aerodynamica is going to have to be good too..
i know what your saying mines is going to be sleeper status too..but im sure the new intercooler will show some type of sign dat your either built or semi built
as for pressure test if u mean compression test...all you gotta do is unplug your EFI fuse and your igniter so you dont catch spark...but its better if your car is warmed up...then just go down the line and do your compression test screw it on crank till you get a steady reading then repeat for the other five
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
Old 07-27-2007, 10:58 AM   #7
IHateHacks
IHateHacks's Avatar
No, you unplug the EFI fuse so you don't spray fuel in the cylinder while you test the cylinder compression. Liquids don't compress.
I agree, make sure the head gasket its good, then perform all maintainance. Timing belt, tensioner, fuel filter blah blah blah.
Then get a turbo back 3" exhaust, and coilovers. Get the best your money can buy for a supra, don't cheap out.
Old 07-28-2007, 04:51 PM   #8
zuni
zuni's Avatar
Arrow
im still lost as to what a compression test is and how to do it.
Old 07-28-2007, 07:36 PM   #9
88Tsupra
i think a compression test just makes sure all your cylinder is working..im not sure though
if your a turbo car check the TSRM itll show you how to do da compression test...
first you unplug your EFI like ihatehack said..buh i always unplug the coil pack just in case....
then you just take your compression tool and screw it on each spark plug one by one
then with about five cranks of the motor.(meaning try & turn on the engine) until you get a steady reading on your compression gauge
den repeat process for the other 5 cylinder
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
