Old 07-21-2007, 07:44 PM   #1
kidthunder650
kidthunder650 is on a distinguished road
Default no spark possiable causes?
my mkiii turbo died a few weeks ago. i had it running about 90% good and then it shut down.
i have no spark, anyone know of anything that usually goes on this car or what should i check.
thanks the weekends are the only time i get to work on this because of school/work....
i have battery voltage going to the coils. weird and coils have .8 ohms resistance so they are good.
kidthunder650 is offline   Reply With Quote
Old 07-21-2007, 08:03 PM   #2
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
maybe bad ignition wires?
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
oowee623 is offline   Reply With Quote
Old 07-21-2007, 08:22 PM   #3
kidthunder650
the wires are good.
when i check the pig tails going to the coils one wire has battery voltage.
should the other wire be ground. if i test that wire and battery ground i should beep on the meter because they should be grounded right.
Old 07-21-2007, 08:49 PM   #4
supradaddy0803
supradaddy0803's Avatar
It really all depends on how old those wires are. If you take one of the wires off and point the spark plug end of it to a ground you should see a nice bright blue arc. If you dont see that then it is a good possibility they are bad. If you are not getting spark to the plugs then it is gonna be the coil or the wires or the plugs not much other than that cept like a crank sensor or something. But that part is just a magnet so if the coil is getting voltage take and check with your probes ground one and put the other in the number one coil pack if you dont get some real voltage besides battery voltage the I would look at the coil if you get high voltage there (because the coil ramps the voltage of battery power up) then ohm out the cables. They should be a max of 25k ohms if they are greater than that then they are bad that is straight from the TSRM. I have had 3 supras in my life a 84, 86.5, and a my 87 never seen a coil go bad the plugs wires go bad way before they will.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
No spark issues DDBT MKII Supra 2 01-06-2009 07:08 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
no spark supraboy8809 MKIII Supra 1 10-14-2006 11:31 PM
