Old 05-24-2005, 10:25 AM   #1
Supra GuestAlby
Guest
Posts: n/a
I have the 1jzgte and have had idle troubl when engie hasn't warmed up all the way. Have had a look on the net. aparrently someone has fixed the same problem by "take out and clean your ISCV" What is an ISCV and where is it.
Old 05-24-2005, 10:46 AM   #2
i wish it was that easy lol
but hey... try it... who knows it might be your problem
isc is the idle control valve, on the 1jz i believe it is at the back of the intake manifold closest to the firewall... has quite a large round unit bolted on by two bolts, inside that is the little disc which is a filter and black rubber o seal
pull em out, clean up the filter or see if you can possibly get a new one and just clean out where the filter sits
lmk if this does fix ur idle problem
Finally, Idle Set! scruffboy Non-Generation Specific Questions 6 01-16-2007 02:39 PM
Idle problem 1988 Supra non turbo jimwww Non-Generation Specific Questions 3 01-24-2006 03:50 PM
