Old 07-11-2007, 12:31 PM   #1
89n/aA/T-2turbo5spd
89n/aA/T-2turbo5spd is on a distinguished road
Default 7mge swap, electrical problem
Hi, as some of you may know i did a swap from a non-turbo auto, to a JDM 7mgte 5 spd. I have one big problem, as the japanese wire harness is made for a right hand drive, it wont work. Also the connectors are a bit different, any suggestions. Greatly appreciated Thank you.
-Mike-
89n/aA/T-2turbo5spd is offline   Reply With Quote
Old 07-11-2007, 05:53 PM   #2
supradaddy0803
supradaddy0803's Avatar
I ran into the same problem with my 1JZGTE swap the different connectors are a easy fix just have to find them and splice them into your wireing harness. If you go to a dealership and take the connectors they should be able to get them. I lucked out because I had a clip and just cut off the ones I needed. As for wiring them there is quite a few people out there that have a wiring diagram that will work for you the colors should be the same just in different places on the plugs.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 08-07-2007, 03:58 AM   #3
tone loc
tone loc's Avatar
or you can find a new harness for the oem supras and pay like $500
Old 08-10-2007, 08:04 PM   #4
89n/aA/T-2turbo5spd
I have one question for you, where did you get the diagram from? As I need one. My car was a 89 non-turbo, automatic, and I have switched it over to a jdm 7mgte 5spd. I just really need a wiring diagram, I can splice them together/solder. I was looking for a extension for the wiring harness, as the japanese wiring harness is too short, because it was from a right hand drive japanese supra.
Old 08-15-2007, 05:23 AM   #5
89n/aA/T-2turbo5spd
bump for my question
Old 08-15-2007, 06:51 AM   #6
Here's an online copy. I recommend buying a copy though, it's alot easy to thumb through a printed version and as long as sales continue Toyota's more likely to keep publishing them.
I suspect it would be easier to convert your original harness.
http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=002
4runner 7MGE swap idle problem grabber MKIII Supra 3 06-26-2008 11:45 PM
7mge to 7mgte swap doodah Non-Generation Specific Questions 1 01-28-2007 06:50 AM
7MGE to 7MGTE SWAP! teedoff00 MKIII Supra 6 11-18-2006 07:58 AM
Engine swap 5mge for 7mge eternal genome MKII Supra 12 03-04-2006 09:20 PM
