Old 07-10-2007, 06:15 PM   #1
go.stfu
go.stfu's Avatar
go.stfu is on a distinguished road
Default Timing belt is escaping!
So I'm driving along in front of a mexican in a neon'd-out El Camino pimped out with fuzzy dingo-balls when I hear a "cruhggrukurkukeherrr" (sp?).
He pulls along side me and I complement him on the fuzziness of his balls and then smile and point at his engine.
He smiles back and shakes his head. He then points at my engine.
So I turn down the euro-techno and realize that the sound was coming from my engine!!!!
So anyways... my timing belt seems to be slipping off. =/ (it's like 1/4 off)
Does this usually happen due to bad tensioners or is there something else I should be looking to replace?
Thanks for the info.
1985 manual (r.i.p) -- 1989 automatic (new)
http://www.cardomain.com/ride/2635827
go.stfu is offline   Reply With Quote
Old 07-10-2007, 08:10 PM   #2
supramacist
supramacist's Avatar
Chances are you didn't get the pulley out to the propper 75 lbs of torque before you tightened it. I would check that before the tensioner.
Old 07-10-2007, 09:16 PM   #3
IHateHacks
IHateHacks's Avatar
Sounds like your crankshaft timing sprocket is messed up. The cogged pulley that goes on the crank behind the aluminum lower timing cover that the timing belt is driven by.
Nothing is torqued to 75ft/lbs down there. Crank pulley is 195ft/lbs and the timing belt tensioner is 36ft/lbs.
Old 07-11-2007, 01:21 AM   #4
supramacist
I'll double check that in my tsrm. I could have swore it was 75 lbs because I was worried I didn't hit the mark.
If it's 36lbs, I'm golden.
Old 07-13-2007, 02:49 AM   #5
mrnickleye
mrnickleye's Avatar
The only reason the belt will move forward on the gears is because the "washer" that is part of the t-belt drive gear on the crankshaft has come loose from the gear.
The Toyota dealer can get you one over night for about $85.
Best to change the t-belt too, as it has now been damaged.
Better to NOT drive the car until fixed.
Old 07-13-2007, 03:21 AM   #6
go.stfu
go.stfu's Avatar
I finally have everything taken apart.
The washer you speak of is the thin black ring that is set into the lower timing cover right?
Can I reattach it or do I have to replace the gear?
Old 07-13-2007, 06:31 AM   #7
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
if i recall that timing gear should be a one piece unit, you will need a replacement
do everything while you're there since it's apart
crank seal and cams, timing belt, tensioner
Pics of my build.
Do a diagnostic first!
Old 07-14-2007, 10:38 PM   #8
mrnickleye
mrnickleye's Avatar
Yes. the t-belt crank gear comes as a one-piece item. Those 'washer' looking ends are put on at the factory with a machine. If you look very close (magnafying glass helps), you will see small crimps in the metal that hold those washers to the gear.
Mine did the same thing. I have lots of experience with 'out-in-the field', and home remedy repairs, so I spot-welded the washer onto the gear.
I don't recommend this procedure to everyone.
Timing belt tensioner HELP ! lobosupra MKIII Supra 1 12-11-2008 11:52 PM
Broken Timing Belt detroitsupra MKII Supra 3 03-10-2008 11:06 PM
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
Timing belt... h8z2luze MKIII Supra 3 05-29-2006 01:52 AM
Timing belt rubbing against lower front cover adamh88 MKIII Supra 4 01-05-2006 11:08 PM
