Old 07-10-2007, 06:29 AM   #1
88Tsupra
88Tsupra is on a distinguished road
Default Fuken BS died at idle while it made pop noise
well tonight i was driving home then stopped at a light and it started to pop while it idle so i rev it a lil still does it pops and pops then it dies took me about 10 cranks to start it back while i smelled suming burning...i will be checking my plugs tomorrow and my coolant is leaking again fukn bs man im tired of this the coolant is leaking to the ground i might b spending either all day tomorrow or wednesday on the car...n e help why the car poppped when idel then died sounds like a misfire
i got a check engine light earlier dat day for about 4sec then went never popped back...im reading last time i check code 51 did a compression test got a code 12 and 14
edit ...check engine light came on earlier dat day
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 07-13-2007, 06:37 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
sounds like an interesting problem you have there
code 12 14.. are those like rpm or starter signal?? can't remember right now
do a fresh diagnosis and get back to us
51 i believe is tps.. check the plug make sure it's firmly plugged and check/adjust as per tsrm
Pics of my build.
Do a diagnostic first!
Old 07-14-2007, 07:52 AM   #3
88Tsupra
i reseted my code and it cleared all but the code 51...i get less pop unless im being stupid and hittin red line..buh its feeling better i just needa fix the 51..thanx
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
Old 07-14-2007, 07:55 AM   #4
51 is specifically the TPS IDL switch or the NSW switch (on autos). You'll throw a code 51 if you rev the engine while the diagnostic is jumped as well.
Old 07-14-2007, 08:03 AM   #5
88Tsupra
mm dat code be it buh i couldnt get rid of the code 51 even after i tried to reset and made sure the TPS is on the original toyota spot
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
Old 07-17-2007, 05:52 PM   #6
88Tsupra
hey i had that problem again yesterday were it did a violent pop like a misfire again..my uncle thinks my timing is off but last time i check my timing was 10degree buh my CPS might be off cuz i know everything i do somethign with the car it wont start until i adjust it then put it back to were it was to work
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
