Old 06-21-2007, 04:04 PM   #1
OfnaRcR
OfnaRcR is on a distinguished road
Default What do you think?
Turbo death whine or something else?
Didn't do it on the test drive but on the way home it started doing this.
http://videos.streetfire.net/video/d...53001646e9.htm
OfnaRcR is offline   Reply With Quote
Old 06-21-2007, 04:43 PM   #2
dcrusupra
dcrusupra's Avatar
Pull off the intake hose to the turbo and check to see if there is any shaft movement. Push in and pull on the impeller blades. If it moves then it is bad. Also move it side to side. If it moves a lot the it is bad. Also start the car and then look at the impeller blades. See if they are moving.
Here is a video of the death whine
http://video.google.com/videoplay?do...39221222&hl=en
New Rebuild
My CarDomain
Old 06-21-2007, 06:05 PM   #3
OfnaRcR
I forgot to say that i pulled the hose off and checked for play. It had no in and out but it had some side to side. I have little experience so i can't tell you if it was a lot. I will go out and check for spinage at idle and such. Some people are saying a possible boost leak?
Old 06-21-2007, 07:21 PM   #4
dcrusupra
dcrusupra's Avatar
It could be, but if it was a boost leak, it would be throwing a code 14.
New Rebuild
My CarDomain
