Old 06-17-2007, 01:01 AM   #5
carfanatic89
carfanatic89's Avatar
I had the same with mine. I bought it and 1 month later it started knocking. It wasthe rod bearings. If it is them in your case then pull the engine and check them make sure the rod bearing caps in the right place,where you pulled them off from. check the main bearing too. Befor you put the new rod bearings on make sure there are no groves in the crank. Make sure you put the caps back in the orignal place they cam from
Bottom end rebuild or replace engine ? lensosupra MKIII Supra 3 05-06-2008 12:19 AM
7MGE Engine Rebuild SilenceboneSupra MKIII Supra 1 10-23-2007 06:45 PM
Need help! Trouble after engine rebuild joebuffalo MKIII Supra 1 04-29-2007 09:54 PM
1988 supra engine rebuild 1988Suprakid MKIII Supra 5 06-07-2006 09:07 PM
New Engine Or Rebuild Help ! ! ! ! ! DarkRaiderz MKIII Supra 5 01-23-2006 01:21 AM
