Old 05-17-2005, 05:52 AM   #1
tam714
tam714 is on a distinguished road
okay i just got my 1988 supra turbo about 3 weeks ago, i have some questions that i might think be problems.
- it accelerates slow, but after it gets to about 30mph and the turbo kicks it accelerates pretty fast, but heres the thing, sometimes after i go on the freeway and go like 80 mph for a bit and get off, the accelerations seems to be fast? it's weird
- this car is an automatic, but i can't really feel my gears change, like the rpm doesn't drop when the gear changes and you can feel the gear change in regular auto, is there something wrong with my car?
- this has something to do with the above question. um after this one time i drove on the freeway for like 40 minutes, and got off, i could actually feel the gear changing and see the rpm drop a lil everytime it changed gear, wtf is going on haha
- last but not least, about how many miles should i get on a full tank? thanks
and btw to make me feel a little better, i got the car for 1100. =] i think that's an okay price thanks
tam714 is offline   Reply With Quote
Old 05-17-2005, 11:12 AM   #2
KingDiamond
KingDiamond is on a distinguished road
First I would start with a visual inspection under the hood, look over everything, vacuum lines, wiring, andything dirty clean it up. Look for anything that don't look right, and then if everything appears to be kosher i would go ahead and see if i could pull some codes from her. You could also maybe do a transmission oil pressure test. Another option since its a automatic, maybe something to do with torque converter. But start with the most obvious and do a visual inspection of everything.
KingDiamond is offline   Reply With Quote
Old 05-29-2005, 05:49 AM   #3
hangsupra
if i were you i will start checking on my trainny fluid first. sometime it does that to
Old 05-30-2005, 09:46 PM   #4
monkihead
SP58GT
monkihead's Avatar
if im not mistaken, autos take a bit longer for the boost to kick in. your tranny may take a crap pretty soon. suprragirl is experienced on the auto, you may want to pm her.
monique- better off dead
Old 06-12-2005, 10:37 PM   #5
pabrosmc
pabrosmc is on a distinguished road
need parts for your car?
selling
stock turbo
slightly used stock radiator (barely new)
2 front tokico struts
call me at 5625878461
or email me at pabrosmc@sbcglobal.net
pabrosmc is offline   Reply With Quote
Supra n00b please help! Norikumiin MKII Supra 4 07-18-2005 08:38 AM
NEED SOME SUPRA HELP! tytyguy MKIV Supra 1 07-11-2005 01:31 PM
Need Super Help! tam714 MKIII Supra 4 06-09-2005 02:20 PM
Im New, Going from a V8 to a supra maybe? Help! Deadtoday Non-Generation Specific Questions 9 05-24-2005 11:10 PM
used Japanise motor Rpms wont go past 3.5!! Help! Supra89redJapaniserebuiltEng. MKIII Supra 0 12-30-2004 10:04 PM
