Old 05-30-2007, 05:28 PM   #1
Arne (Denmark)
Arne (Denmark) is on a distinguished road
Default 7MGE oil pressure
Hi there. My first time here.
I have a 1987 MKiii Supra (7MGE) which I bought three months ago.
I topped up the oil with some Mobil 10W40 oil even though the guy I bought it from said I should use 15W-40, because the mileage is about 250.000 km
The problem is that after that the oil pressure has tuned down quite a bit. Normally the pressure idling was 1.7 kg/cm3.
Now I can hardly get the pressure to rise to more than 2.0 and it's generally too low. -Only about 1.0 idling.
AND there is a rattling, knocking from the engine!? Nothing when it's idling but gets bad about 2000-3000 rpm. Hmmmm.
Have you guys ever had or heard an oil pump go bad?
What is your normal oil pressure reading on the cars?
Can a faulty bearing cause the oil pressure to fall?
After all I hope it is only my oil pump otherwise I got to look around for another engine.
I will be happy for your comments.
Arne (Denmark) is offline   Reply With Quote
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
How far can you push a 7MGE on turbo? Turbotuner2.3 MKIII Supra 6 10-26-2007 09:12 PM
oil pressure guage in nonturbo 7mge nosd112 Non-Generation Specific Questions 1 07-05-2006 08:09 PM
7mge vs. 7mgte KNYFE MKIII Supra 3 09-27-2005 02:21 PM
