Old 05-21-2007, 01:55 AM   #11
supradrift
supradrift is on a distinguished road
so your saying that eventually its going to need better cooling anyway right??
supradrift is offline   Reply With Quote
Old 05-21-2007, 02:17 AM   #12
I'm saying that what you're going to *need* will depend on your build. BUT, if you're going with a new rad might as well pay a few extra bucks and get a good quality high flow one and have all the bases covered from the start.
EDIT: Also, since you're going to have to drain the system, you might as well take the opportunity to flush the system well, replace the thermostat and rad cap.
Old 05-21-2007, 09:21 PM   #13
supradrift
well thanks for the help im going to go with the fluidyne and see what happens
Old 05-31-2007, 02:47 AM   #14
supradrift
thank you for the input everybody, i went with the fluidyne and so far i am happy with it i put it in no problems everything worked great and looks awesome just to let anybody thinking about a radiator it is worth the money
Old 06-01-2007, 08:52 AM   #15
oowee623
oowee623's Avatar
do you have an electric fan to go with it? i heard going electric add up to 15hp rather than using a belt driven fan.
more info here
http://www.supras.nl/index.php?optio...d=53&Itemid=69
Old 06-05-2007, 11:43 AM   #16
sprigmo1
sprigmo1's Avatar
sprigmo1 is on a distinguished road
Default Radiator
I went with a CSF Racing radiator! They make the stock replacement and within the last 2 yrs started making drop-in race radiators for the 7M. Cost is great and so is performance!
Malik
" It Ain't Eazy Being Me"
1992 Supra /TSW 618 Rims/Goodridge Brake Lines/Powerslot Rotors/Eibach Springs/Tokico/KYB Struts/ST Sway Bars/Cusco Strut Bars/Targa Bars/RPS Clutch/C's Shifter/Aero.AFPR/RC 560cc Inj/Walbro Fuel Pumps/Lexus AFM/HKS Timing Gears/K&N Intake/HPF Intercooler/Greddy BOV/Turbonetics 60-1 CT26/CSF 53mm RAD /Apexi S-AFC /Apexi AVC-R /Apexi N1Exhaust/RT DP/RT Cat/Jegs Catch Can/Greddy TT/Blitz Boost/EGT Guage/Blitz Peek Hold Device/Lotek Dual A-Pillar Pod/AEM UEGO WB
sprigmo1 is offline   Reply With Quote
Old 03-29-2011, 09:58 PM   #17
chippies
chippies's Avatar
chippies is on a distinguished road
i jsy got a new head gasket fixed n i got a new radiator after that n just today my radiator blew up i thought it was the engine dump that blew but wen i refilled the radiator it kept leakin n never filled up....did my radiator blew out i think but im wonderin wat was the cause does anyone have a clue o n i filled it up with 50/50 coolent so pls help im fucken pissed n confused
chippies is offline   Reply With Quote
Old 03-30-2011, 11:59 AM   #18
supradrift
did it start to heat up did you notice when it happened? repair leak let it run see if it heats up for the price of a thermostat i would start there.if its another bad head gasket after you repair the leak check the over flow see if its bubbling like there is compression in there
