Old 05-18-2007, 10:48 PM   #1
supradrift
supradrift is on a distinguished road
Default radiator choice
i have an 87 turbo and the radiator started leaking, so i had it epoxied. turns out the epoxy only lasted a few months, now i am looking for a new radiator. In the future i plan on building the motor to about 400 whp but since the radiator is leaking now i am going to replace it. when i rebuild the motor will i have to buy a high performance radiator? id rather buy it now instead of buying the stock one then find out i need the nice aluminum one.
any information on this will be appreciated.
supradrift is offline   Reply With Quote
Old 05-18-2007, 10:58 PM   #2
I'm running a Koyo and I'm very pleased with it. The Koyo isn't a 100% direct fit, you need to shave a little rubber off the lower mounts, add a plug from a subaru to the temp sensor location (unless you're adding a temp sensor or going 1JZ) and add a small piece of metal to clamp the aux fan down at the bottom... all in all it took me about 30 minutes.
There are really only a few choices when it comes to preformance rads that are made for our car or that fit with minimal effort. Koyo, PWR and I can't recall the other I was just thinking of.
The Koyo can be had for just a little more over what a replacement stocker would run... I'm referring to replacements without plastic endtanks. Replacement rads with the plastic end tanks cost about as much as they're worth.
Old 05-18-2007, 11:45 PM   #3
kwnate
SP58GT
I have a koyo on my 1jz car and a Fluydine on my 7m. Both work great, the koyo looks a little better if that matters to you.
Nate
Old 05-19-2007, 01:22 AM   #4
IHateHacks
IHateHacks's Avatar
There is no temp sensor on a 7M radiator.
All the temp sending units are on the water outlet housing or the thermostat housing. Even the low coolant sending unit is on the coolant recovery bottle so I have no clue what you are talking about.
Old 05-19-2007, 02:47 AM   #5
supramacist
supramacist's Avatar
Lol.!!!!
That's some funny stuff.
Old 05-19-2007, 04:16 AM   #6
kwnate
SP58GT
Originally Posted by supramacist
Lol.!!!!
Nate
Old 05-19-2007, 03:00 AM   #7
Yup, that's why you need to plug the hole on the Koyo rad that's for the 1JZ's sensor. :P
Old 06-05-2007, 11:43 AM   #8
sprigmo1
sprigmo1's Avatar
sprigmo1 is on a distinguished road
Default Radiator
I went with a CSF Racing radiator! They make the stock replacement and within the last 2 yrs started making drop-in race radiators for the 7M. Cost is great and so is performance!
Malik
" It Ain't Eazy Being Me"
1992 Supra /TSW 618 Rims/Goodridge Brake Lines/Powerslot Rotors/Eibach Springs/Tokico/KYB Struts/ST Sway Bars/Cusco Strut Bars/Targa Bars/RPS Clutch/C's Shifter/Aero.AFPR/RC 560cc Inj/Walbro Fuel Pumps/Lexus AFM/HKS Timing Gears/K&N Intake/HPF Intercooler/Greddy BOV/Turbonetics 60-1 CT26/CSF 53mm RAD /Apexi S-AFC /Apexi AVC-R /Apexi N1Exhaust/RT DP/RT Cat/Jegs Catch Can/Greddy TT/Blitz Boost/EGT Guage/Blitz Peek Hold Device/Lotek Dual A-Pillar Pod/AEM UEGO WB
sprigmo1 is offline   Reply With Quote
