Old 05-18-2007, 04:38 AM   #1
supraman121
well 225/50/r16 225 (the higher the number the wider the tire) is the width 50 (the lower the number the lower the profile) is the hight and r16 is the rim size i went to tire rack and looked it up, just went for replacment wheels and the repair manual might tell you..
So mine lookes like it should your probly looks more like the tires on my dad tacoma he has 215/55/r14 or somthing like that taller and skinnyer
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 05-18-2007, 10:51 AM   #2
Sonic
Sonic's Avatar
Sonic is on a distinguished road
Originally Posted by supraman121
well 225/50/r16 225 (the higher the number the wider the tire) is the width 50 (the lower the number the lower the profile) is the height and r16 is the rim size i went to tire rack and looked it up, just went for replacement wheels and the repair manual might tell you..
So mine looks like it should your probably looks more like the tires on my dad tacoma he has 215/55/r14 or something like that taller and skinnyer
ok 225/50 R16
225 is your width yes , its 225 mm wide 50 is your sidewall height (50 % of 225 mm) R stands for radial construction and 16 is your rim diameter .
then there's a lot of smaller letter explaining your load index rating speed and construction date ext ext.
Sonic is offline   Reply With Quote
Old 05-19-2007, 04:06 AM   #3
supraman121
well you said "Funny?...wouldn't it just make the car seem to sit higher off the ground?"
My answer was no cause my tire's are a lower profile then yours are. Cause of the 50. I guess i should have said that from the start sry.
K&N Air Filter
Old 05-27-2007, 01:44 AM   #4
btwilson86
Super Moderator
btwilson86's Avatar
Hey guys, the stock size is actually a 205/55/16. You can also run a 215/55/16 (a teeny bit taller) and the most popular, 225/50/16. The last size gives you the most useable tread on the ground, and is back to the stock sidewall height. I work as a tire tech at America's Tire Co., and can look up any other tire info you guys need.
And tire size (X/Y/RZ) works like this:
X= Bead to bead length in millimeters
Y= The percentage of X left over for sidewall height
R= Radial Tire construction
Z= Rim size, in inches (16 inches for stock wheels)
Tire pressure? dannydavi Non-Generation Specific Questions 11 08-16-2007 06:03 AM
turbo or not ??? That's the question ... sausa MKIV Supra 7 03-30-2007 02:22 AM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
Tire Question mrnickleye Non-Generation Specific Questions 5 10-29-2005 07:29 AM
