Old 05-03-2007, 11:39 PM   #1
Revikan
Revikan is on a distinguished road
Default 5 speed issues
I recently got a Supra project. The car wont go in 1st 3rd or 5th because the dash is in the way. Are all dashes the same or could they have put in an automatic dash?
1986.5 MKIII 5-speed NA. Current State= Rebuilding
Revikan is offline   Reply With Quote
Old 05-04-2007, 01:18 AM   #2
supramacist
supramacist's Avatar
I honestly don't know what the deal is lately with everyone buying half built half torn down supras.
Cause it's not hard enought to work a clean one. It looks like someone did a tranny swap and you took it upon yourself to finish the job.
Toyota parts guys are your friends. How about a pic of the engine???
Old 05-04-2007, 01:30 AM   #3
redmaro
Maybe you could try a short shifter.
MK3, Auto, Turbo.
Old 05-04-2007, 01:32 AM   #4
supramacist
A short shifter might get you the clearance you desire.
MIGHT.
Old 05-04-2007, 02:32 AM   #5
tone loc
tone loc's Avatar
is the black part all the way on the grey dash? there is a little button were you put the key in. this button is to take the key out. the black part of the dash has to be behind that button. get us a pic of the engine and tranny if you can
Old 05-04-2007, 02:35 AM   #6
tone loc
tone loc's Avatar
if thats ok then its the postion of the tranny
Old 05-04-2007, 04:55 AM   #7
boogum7
boogum7 is on a distinguished road
Default shifter
is the shifter in the right direction?
take it out and switch it around see if that does anything.
stock
boogum7 is offline   Reply With Quote
Old 05-04-2007, 06:54 AM   #8
Revikan
Its a 5 speed stock. The dash is also in the right way, its behind the little black button on the ignition.
Old 05-04-2007, 10:29 AM   #9
f00g00
Looks like to me the shifter is in backwards. It has a slight bend to it that would have it in the right place if you turn it around with the boot. There are Three boots by the way, two rubber and the shift boot which should be leather.
I uploaded two pics of my car with the shift boot off and the knob off. I tore off the outer pipe also which is why my shifter looks different.
You may have to remove the lower half of the console to remove the rubber boots.
The first pic is in nuetral the second is in 1st gear.
ID:	901   Click image for larger version
Blitz MSTT Speed adjustment SunDan MKIII Supra 5 11-17-2009 07:41 AM
New to MK4 (Auto TT to 5-or 6 Speed TT?) Mattz32 MKIV Supra 2 11-01-2008 06:25 PM
Heat Consistancy Issues Chambers MKIII Supra 14 04-07-2008 12:52 AM
speed o-meter or speed-cable help... hangsupra MKIII Supra 0 10-15-2006 08:54 PM
