#41 |
ok i didnt wanan start another thread so ima just add to this one again
I did my compression test today and it read from 1-6 180 170 170 180 175 170 its strange to me that its around 10 psi apart buh its ok right now i got the low engine coolant still im just thinkin its a leak and yes i did the block test and it came back negative so i take it as the HG is good to go
88turbo targa-white original Pin Stripe custom intake-Tenzo filter.....Momo racing seats and steering wheel... apexi exhaust tip-custom 3" piping. Replaced with RSR GT II NGK plug and wires HID conversion head lights HKS Turbo Timer Type-1 (in black) Tial BOV BIC DDP |
#42 |
Those numbers are within spec. You should not have more than a 14psi difference between any 2 cylinders.
I just ran a compression test on my motor today, check out my post in my head gasket thread. |
| Check Engine Light & Warning light on | Chomper | MKIV FAQ | 19 | 02-11-2011 12:51 PM |
| Funky engine coolant issue | shirkinator | Non-Generation Specific Questions | 1 | 06-22-2009 08:37 AM |
| Engine light and warning light on. | Chomper | MKIV Supra | 11 | 07-18-2008 11:44 AM |
| Engine Light | Supra91_ishot | Non-Generation Specific Questions | 2 | 06-08-2005 12:37 PM |
| 1998 Supra Check Engine Light | SupraLady | Non-Generation Specific Questions | 2 | 12-15-2004 11:39 PM |
