Old 05-01-2007, 11:47 PM   #1
Z'mnypit
Z'mnypit's Avatar
Z'mnypit is on a distinguished road
Default Car runs like crap, spits, sputters etc! HELP
Ok, a little backgound on the car. I bought it with a BHG. got that fixed and ran good for a couple days then I washed under the hood with some greasedlighting to clean it up a bit. Well needless to say that was a bad idea. Everysince then its ran like pure crap. Spits, sputter,no power, backfiring idles fine, want rev past 2500rpm even when it does rev that high its all it will do to get there. I have one SES code being 31 for the MAF. Im pretty sure that isnt the problem though beings the code was there the couple days it ran good.
Ive swapped out all plugs with new ones, changed air filter, cleaned all electrical plugs with start fluid and still runs like crap. Timing is right at 10-12* everything is lined up right. Then again it ran fine for two days with nothing being changed other then washing under the hood.
Yesterday, I found a vacuum leak right at the TB where it bolts up to the intake. Replaced that and the fuel filter today and still runs like crap. Im all out of ideas and cant think of anything else to try since Im new to these cars.
The car is an 87, 5spd, turbo.
Any suggestions?
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car"
408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's
-2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's
- Two 87 turbo'd/targa top'd supras (*Under Construction*)
Z'mnypit is offline   Reply With Quote
Old 05-01-2007, 11:59 PM   #2
west_side_supra
west_side_supra's Avatar
check your spark plugs/wires, then make shur there all plugged in, check you coil pack harness wires because mine melted on me and i had to rewire it, check and little hard for any vacume leaks, test your igniter, because it really sounds like your missfiring.
but your timeing if i recall should be 15 i think, dont take my word im to lazy to look at the motor in my garage, but the 2nd marking from the left is the one you want it at.
also check you cam position sensor wires. mine where melted there, although i was just getting a code 14 and 52, but it ended being the coil pack harness, i mixed a power and ground, its hard to make out them damn faded colors, there green then barley lighter green, then another green.
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 05-02-2007, 12:11 AM   #3
Toyota87Supra
Toyota87Supra's Avatar
Toyota87Supra is on a distinguished road
I did the same thing with my car, and was having the same problems, and was getting the same code. I replaced my MAF sensor and the car ran fine after that. You probably sucked the cleaner through your air filter and it got on the sensor.
87 5speed Targa 7MGTE...
07 Civic Si Stock...
01 Silverado 1500...
Toyota87Supra is offline   Reply With Quote
Old 05-02-2007, 12:42 AM   #4
j3pz
the ignition timing should be 10, some people run 14-15
http://www.cygnusx1.net/Supra/TechTi...ng_timing.aspx
Old 05-02-2007, 01:19 AM   #5
IHateHacks
IHateHacks's Avatar
Base ignition timing should be 10 degrees BTDC not 15. That is base igniton timing, the ECU will provide an electronic advance and, under boost, you do not want more than stock advance.
You definatly messed something up when you "washed" the engine bay. Did you use a power washer, or what?
You probably sprayed the coil packs or the MAF or the igniter and fubar'd it. Time to start testing with a multimeter, do you own a TSRM? If not, there is a link in the sticky's in this forum.
You are never suppost to wash the engine with anything. You want a clean engine? Take it apart and rebuild it, cleaning the parts as you take them off. Looks like you learned the hard way. Sorry.
Old 05-02-2007, 01:32 AM   #6
Z'mnypit
Z'mnypit's Avatar
ALright, so next Ill check the MAF. Ill check on ebay for a new one.
Guess tommorow Ill break out the multimeter and start checking the MAF, igniter, coil packs and anything else I can find.
I sprayed it down with greased lighting and then sprayed it off with a water hose.
I do own a tsrm. Any other suggestions?
Old 05-02-2007, 01:35 AM   #7
IHateHacks
IHateHacks's Avatar
Thats is a big no no.
I find it hard to believe you didn't know you aren't suppost to do that.
Old 05-02-2007, 01:40 AM   #8
j3pz
i have a suggestion: next time you decide to wash the hood, take it off...
/smartassness
Old 05-02-2007, 02:02 AM   #9
redmaro
Good luck buying a new MAF sensor they cost like $400+.
MK3, Auto, Turbo.
Old 05-02-2007, 02:49 AM   #10
Toyota87Supra
go to supramania and ask for a maf sensor i got one for 50 bucks works great... and it got shipped in 1 day
1988 Toyota Supra Turbo runs very rich need help PhillyKorean Non-Generation Specific Questions 0 10-25-2008 03:28 PM
1982 supra runs really rough when cold tylertatum Non-Generation Specific Questions 0 10-04-2005 08:01 PM
