Old 04-21-2007, 10:03 AM   #1
mkIIIdraper
mkIIIdraper's Avatar
mkIIIdraper is on a distinguished road
Default Higher rpm sputter
hello again it's me
does anyone know what the deal is
when i get into higher rpms like 5000 plus my car loses power and begins to sputter it does it more when i switch over to high boost and when i try to go aver 100 mph all i get is sputtering and loss of power
i'm thinking that the cam timing is off a tooth or something
88 mkIII, manual, turbo, hks valve management system, non restrictive exhaust, cold air intake, 15lbs, 12.89 @108 mph
mkIIIdraper is offline   Reply With Quote
Old 04-21-2007, 02:59 PM   #2
redmaro
How much boost are you running it on?
MK3, Auto, Turbo.
Old 04-22-2007, 01:57 AM   #3
mkIIIdraper
i have an hks valve timer that acts as a boost controller so i can switch between stock 12 and 15
Old 04-22-2007, 06:31 AM   #4
88Tsupra
88Tsupra is on a distinguished road
i get the same feeling. i think its just natural. ill show u a importtuner site were the evo drops boost
http://www.importtuner.com/tech/powe...ontroller.html
look at the note near teh bottom it shows how the psi drop
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 04-22-2007, 10:49 PM   #5
supraman121
Fuel cut off? is that 12psi to 15psi? fuel cut offs around there
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 04-25-2007, 07:23 PM   #6
mkIIIdraper
i'm pretty sure the hks unit gets rid of fuel cut
and it does it at normal boost levels too
thanks for the help
spit and sputter swied MKIII Supra 3 04-28-2007 06:08 AM
Engine seems powerless until higher RPMs Ahmad88 Non-Generation Specific Questions 8 06-22-2006 01:58 PM
Sputter @ high rpms with pedal all down! MKIIISupraTurbo Non-Generation Specific Questions 2 11-11-2005 01:47 AM
