Old 04-20-2007, 03:30 PM   #1
supra_91
supra_91's Avatar
Default suspension problem
i just put some eibachs on my car with the stock struts(for now) and as i figured, they blew. im going to buy the tokico blues(i dont have TEMS). are they ok. this isn't my problem though. after i lower the car and had it aligned, they couldn't get the front passenger cam bolts to break loose. this was ok bc it wasn't off very much. that day i noticed a clunking noise from the struts(i assume its from the more stress being put on the stock struts). also i hear a popping noise from the front. it only does this when i turn the wheel all the way to the left or right and move(does it all the time) or when im coming to a stop with my wheels turned(doesnt do it all time). the guy who aligned it said it could be the cam bolts bc it could have broken loose the rust and now moving back and forth. what do you guys think? is it the ball joints?
Old 04-20-2007, 04:55 PM   #2
supradaddy0803
supradaddy0803's Avatar
About the struts I have the illumina 2's on mine you dont need TEMS to use them just adjust them manuely. But anyways they are great little stiff but I like my ride like that. They also look good with the eibachs. As for the clunking noise mine did that and it was the tie rod ends the right side was borke I replaced it went away. Easy way to check it remove it from the spindle and move it around if it is broke you will feel cracking inside of it they are pretty cheap. They were prolly broke and when he did the alignment it got worse.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 04-20-2007, 04:56 PM   #3
88Tsupra
88Tsupra is on a distinguished road
http://www.toyota-supra.info/forums/...ead.php?t=7749
dats the thread i started about the same problem hope that helps
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 04-20-2007, 05:51 PM   #4
supra_91
supra_91's Avatar
the popping noise is worse after the alignment than before. i does it and i dont have to turn the steering wheel all the way. i doesnt do it when im driving 10+
Old 04-21-2007, 06:42 AM   #5
mrnickleye
mrnickleye's Avatar
Check TSRM for testing BJs. Check FAQs section on lower ball joint replacing. Been there, done them. Last Month.
Possibly the lower control arm bushings. There now,
http://www.suprasport.com/ has some, $150 set.
Dealer has only the whole arms, $187 each side.
Old 04-21-2007, 07:53 AM   #6
supramacist
supramacist's Avatar
You'll shoot yer I out.
If it's doing it when you roll, and your'e driving it.
It's going to get worse. This isn't the kind of thing you want going out while your'e on the bypass or interstate. I wouldn't drive it unless I had to.
But i'm the kind of guy that'll not go to work because my car is sick.
Old 04-22-2007, 04:05 PM   #7
supra_91
supra_91's Avatar
i checked the ball joints and their ok. i squirted some WD40 on the rubber stops and it hasn't made the noise since. i guess it was just a coincidence that it got worse after i aligned it
Old 04-24-2007, 01:49 AM   #8
supra_91
supra_91's Avatar
do i have to get the car realigned after i replace the struts. i just had it done when i put the eibach springs on. they couldnt get the passenger front cam bolt to loosen but they said it wasn't very far off
Old 04-25-2007, 03:16 PM   #9
supra_91
supra_91's Avatar
does it need realigned
Old 04-25-2007, 04:32 PM   #10
supramacist
I wouldn't think so if you replaced with oem.
But you will know within a mile of driving if it needs to be or not.
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
Need hlep with suspension problem. abhattan MKIII Supra 7 03-06-2007 03:43 AM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
