Old 04-13-2007, 08:15 PM   #11
supramacist
supramacist's Avatar
I know to some of you turbo's are worth it. I wouldn't mind having one on a car that I would never work on. Like a porsche maybe. I just simply like not having the extra headache. My na is plenty quick for what it is when it runs and it will be again soon.
I'm not knocking you guys for doing the turbo thing. To each there own.
Old 04-13-2007, 08:18 PM   #12
redmaro
You say that cause your N/A.
MK3, Auto, Turbo.
Old 04-13-2007, 08:25 PM   #13
tone loc
tone loc's Avatar
Originally Posted by Supra2NR
About the aftermarket intake manifold it is quite expensive to get that if you can find it, and if you do it about 600 bucks not unless you make one for yourself
Pretty expensive and don't waste your time with the ct26 turbo they tend to break with higher boost levels
Get urself something with at least a 60 trim
Or go 70 trim for bigger power
If you want a ball bearing turbo I suggest looking at the garett gt35r turbo that's should be enuff for your needs for now
It is a bit pricey but it'll be worthit
You need to get an aftermarket exhaust manifold too, top mount with a t3/t4 flange
You need a wastegate too at least 40mm
And doing all your pipiing you might wanna start looking for aftermarket bov to compliment your intake piping
I suggest getting a front mount intercooler too,
And yes the 4 inch is a little overkill
But it makes me wonder how were you planning to route that exhaust since there's barely any space underneath the car
thanks man. yeah i guess 4" is a little to much and i didnt even think about the space.
Old 04-13-2007, 09:04 PM   #14
supramacist
I said it because I don't do turbos. I'm not heated. I just like old school things I like an engine that is 300hp because it's built that way. Without turbo's.
I don't spray either. Now if I'm playing gran turismo or something..., I like turbo's.
I like low end torque that I can feel all the way through every gear.
In my experience with turbos. The cars are dead on their faces till 2.5 or 3k rpms. I have never driven a turbo'd supra.
Give me an engine that gets the same power as the turbo, without it. That's my focal point. I know I am in the wrong market for that thought process, lol.
But that's how I think. Let me get my na running and then I'll race what's in my class and be happy. I do more street than track.
Straight line is fun, don't get me wrong. For me the zen of it is in really driving my auto.
Again I'm not saying I wouldn't have a turbo'd car. It's going to be something new enough that I won't have to work on it unless I want to.
Old 04-13-2007, 09:49 PM   #15
west_side_supra
west_side_supra's Avatar
some vehicals that are turbo'd suck and should have never had a turbo, but in the case of a supra, the second that turbo kicks on its a hold your shit moment, expecially when you upgrade it, a turbo is like nitrous besides the point its not going to blow your motor after 5 uses its just helping the motor with more air intake. the more air the more power, but in order for you to have the air you need fuel to support it.
let me put it this way, i have a 1979 camaro with a 350 w/450hp and it was fun just like the supra its big long and heavy, it doesnt stick in the rain very well neither. but when i went and i test drove my turbo'd supra i had the biggest smile ever and the supra was completely stock. everything about the car was amazing. i love cars because the amount of power they have, i like to work on making cars faster so i can be faster than that damn little honda that thinks he is fast with his 4 inch muffler and a cold air intake system and a little engine cover that says v-tech when most of the time they never are. now those little bastards are putting turbos on there cars and trying to stay up and doing a pretty good job. thats when we upgrade our turbos because our motors where built for a turbo and we can push more boost than they can. meaning no chance. you NA i never test drove one but i have raced one before and he had put 6k just in rebuilding and performance wise he got new headers and exhaust and intake, and he stayed up till i got to 2nd gear then i just wasted him out of the hole. so that is why the turbos are great. if you want to see a good diffrence between a NA and tubo, test drive the VW beetles go and test the NA versus the Turbo you will feel the diffrence
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 04-13-2007, 09:56 PM   #16
redmaro
I agree.
MK3, Auto, Turbo.
Old 04-13-2007, 10:42 PM   #17
Supra2NR
Supra2NR's Avatar
So tone loc, I hope I've help you with ur question, and hopefully ur build wil go smoothly
And redmaro, I have that pic that u requested, idk if u saw it already
And turbos rule, as for getting a car and never working on it
For me that's like having a girlfriend, that I pay for everything already, and pay sumbody else some more to fondle her
Lots of reason why pple get the turbo supra
Ie;
"I wanted the new supra, but all I can afford is the mk3"
"I'm an old school guy" etc etc
Plus even if the mk3 is a headache
That comes with any car, if a brand new car breaks down , then what do you expect with a 20yr old car,
And if you don't want the problem when upgrading the turbo, then keep it stock to all factory specs and you won't have a lot of headaches
Old 04-13-2007, 10:53 PM   #18
west_side_supra
yup evey car will break down eventually. but if you want speed and power but only have 4-5k$ then you might want to look into a turbo supra. alot better than paying 4-5k$ on a stock honda that will get its ass kicked. but i guess if you want better gas mileage then get a hyundai low in cost good with gas and acually have a little power to them. plus you get that really cool warrenty.
fidenza cam gears
Old 04-14-2007, 01:08 AM   #19
supramacist
Dudes....,
I'm not knocking turbos. Not at all. I realize there is a huge difference between my na and your turbos. The na is a totally different animal, I agree.
I didn't intend to start a debate. But what the hell. I like to smoke Hondas. Because it seems all those guys think they are hot for some odd reason. So again I agree.
I'm just complacent with the na. And ya everything breaks down sooner or later. It's just an honest preferrance just as yours is for turbos.
Surely we can all agree that we dig the smell of gasoline and oil. Smells like Freedom to me turbo'd or not.
Old 04-14-2007, 01:25 AM   #20
IHateHacks
IHateHacks's Avatar
Personally I like the smell of burning coolant....mmmm my favorite smell in the world.
Exhaust for 7MGE XtreeX MKIII Supra 19 03-25-2010 01:39 AM
making an exhaust mr.w MKIII Supra 4 02-17-2008 01:25 AM
exhaust w/ out intake? sd88supra MKIII Supra 2 03-13-2006 03:22 AM
Exhaust, Headers, Intake XtreeX MKIII Supra 6 02-07-2006 05:34 AM
If U Upgrade Exhaust Must U Upgrade Intake scruffboy Non-Generation Specific Questions 12 12-23-2005 06:35 PM
