Old 04-17-2007, 06:03 AM   #11
j3pz
evo=supra? i missed that one ok time for bed
Old 04-18-2007, 09:23 PM   #12
Supraman
Supraman is on a distinguished road
The new gasket did not change anything. I'm going to look into getting a new manual boost controller. I've got a turbofx the high performance one. Some people have told me they were notorious for giving you a boost peak before leveling off. I'm checking into Greddy or HKS. Anybody using these brands of manual boost controller? Or if someone can recommend a good brand it would be appriciated. Thanks
Supraman is offline   Reply With Quote
Old 04-19-2007, 04:52 AM   #13
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
this iswhat my DSM friends use.. i also just bought this from HPF.com but it is not installed yet.
HALL ESKIT Hallman ES Kit Boost Controllers 1 55.00
My 1989 toyota supra mods:83.5 mm bore, ARP main studs, ARP rod bolts,rings, Cometic .060" headgasket, ARP head Studs, Ferra 1 mm oversized valves, port work, Rc 550cc injectors, Walbro 255hp
Turbo: 1.15 A/R T4 twin Scroll turbin - journal .60 A/R compressor, Hallman Pro MBC, Turbo XS Blow-off Valve, 50mm wastegate, hks fcd
Intercooler: 32x12x3 core, 3 inch piping, with clampco t-bolt clamps
Exhaust:Exhaust manifold T4 twin scroll,2JZ 3 inch downpipe Fabed up to fit, Mandrell bent 3in back
Supra_87_mk3 is offline   Reply With Quote
manual boost control in cab joel w MKIII Supra 2 09-18-2005 03:48 PM
