Old 04-10-2007, 01:56 PM   #1
Supraman
Supraman is on a distinguished road
Default wont hold boost
I have a 1991 Supra Turbo. I've got all the upgrades including lexus afm, stage 3 ct-26, manual boost controller, custom exhaust,mhg,550 inj,custom fuel pressure reg,greddy blow off valve and walbro fuel pump. I noticed when I took it to the track this weekend that it would not hold boost when I would first launch it would go to 15 then drop to 11. So after the first run I turned the boost up a full turn which is equal to 4 psi. Ran down the track agian and the same thing 15 to 11. So the next run I turn the boost up again and again the same thing 15 to 11. So I checked all my hoses, vaccum lines and even check the boost controller and I cant find anything wrong. Its not smoking at all and idles good. Anybody have a clue as to what is going on? Thanks for any suggestions cause I'm stumped.
Supraman is offline   Reply With Quote
Old 04-10-2007, 07:54 PM   #2
ddmcse
ddmcse's Avatar
Cool
i think you missed a line somewhere . even a little tiny hose on the opposite side of the engine will cause this boost leak
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 04-11-2007, 02:08 AM   #3
marc
u only run 4psi thru ur car? u said i turned it all the way up which is equal to 4 pai. 4lbs in a set up like that?
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 04-11-2007, 02:39 AM   #4
dannydavi
dannydavi's Avatar
he said he turned it up a full turn, not all the way up.. a full turn seems to be equal to 4 psi.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 04-11-2007, 05:30 AM   #5
j3pz
what i would do is with the car running, open the hood and either have someone rev it, or you can do it yourself with the throttle linkage, and rev it till it boost and listen for a leak. if you cant hear one then find the vacuum line diagram on the tsrm and check all the lines. let us know hoow it goes.
Old 04-11-2007, 06:24 PM   #6
Supraman
Thanks I'll check it this weekend and let you know.
Old 04-11-2007, 07:20 PM   #7
j3pz
ill go ahead and post the vacuum diagram for you so you dont need to waste time looking for it, plus the more im on here the less i have to do homework here ya go. taken from http://http://www.cygnusx1.net/Supra...cuum_hose.aspx
that has all the other vacuum diagrams too (cruise control, heater, etc.)
Old 04-16-2007, 03:00 PM   #8
Supraman
Well I looked for a vacuum leak. Still cant find one. So when I started it to take a test drive I found that I had an exhaust leak from directly behind the turbo so I tightened it down and took it for a run. It got to 18 then dropped to 14. So Im going to replace the gasket and see if that cures the problem.
Old 04-17-2007, 12:18 AM   #9
supradrift
supradrift is on a distinguished road
let me know if that cures the problem cause i have the same problem i tightened mine up and it still leaks so let me know
supradrift is offline   Reply With Quote
Old 04-17-2007, 04:30 AM   #10
88Tsupra
88Tsupra is on a distinguished road
Default i've read
well i was reading i think either importuner and they tested a evo 8 and it lost as it got closer to redline heres the line from import tuner
((showed boost to climb to a peak 20.6 psi as it quickly tapered off at 6000rpm to 16psi then fell flat on its face to a mere 13psi at 7000rpm. ))
http://www.importtuner.com/tech/powe...ontroller.html
thats the website so the boost drop might be normal..but i could be completely wrong
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
manual boost control in cab joel w MKIII Supra 2 09-18-2005 03:48 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
No boost in neutral but boost in gear! edgardo MKIII Supra 5 10-09-2004 04:01 AM
