Old 03-28-2007, 10:12 PM   #1
kidthunder650
kidthunder650 is on a distinguished road
Default codes 22 24 31
my supra was running ok when i baught it. it had some problems under boost but when crusing it ran good. suposbly has a rebuilt 7mgte and a new stock turbo, and various new parts here and there.
now its running like compleat crap and blows tons and tons of thick black smoke,
it doesnt always start and is not driveable. i changed the plugs and fuel filter.
i just went out and got codes 22 24 and 31 out of the car. i had unplugged the computer and battery and waited about an hour went out got the car started. that was a project in it self, ran it for about 10 minutes and then checked codes. the car ran like ass and wanted to die the whole time.
the person before me didnit align the cam sensor correctly and i can not figure out how ethier. i know this is contributing to my running problems.
my temp sensor is broken so i know thats what code 22 is for. i havent looked at code 24 yet, that is an intake air temp code.
code 31 is what i think might be my problems. that is a air flow meter code for a 7mgte engine. that would be my maf sensor on the intake tube, correct? This would make the car run like crap if it was broken.
if anyone has one laying around i would be glad to buy it as its worth a shot in fixing my car.
kidthunder650 is offline   Reply With Quote
Old 03-28-2007, 11:36 PM   #2
JunkerMK3gte
JunkerMK3gte is on a distinguished road
now your codes r one thing. i build turbo cars for a living. that black smoke is oil. check your turbo. under load oil will seep past the ceramic seals, will end up burnig makin black smoke. now your computer is self componsating. which means it adjusts itelf. the o2 sesor picks up bad exaust, puts more fuel, more air but it gets worse. thats your air code. check the turbo
JunkerMK3gte is offline   Reply With Quote
Old 03-28-2007, 11:49 PM   #3
ddmcse
ddmcse's Avatar
Cool
the black smoke is a bad air fuel mixture
too rich
oil burns blue
i would check the egr vsv and the fuel vsv on the intake side onder the intake manifold
it's a simple continuity check and they are about 40$ each
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 03-29-2007, 12:35 AM   #4
kidthunder650
i thought oil was blue smoke. this is black smoke. the person before me took alot of things off the car. no emmisions no ps or ac crusise, ect.
what should i be checking on the turbo, i am new to turbo cars, first one.
Old 03-29-2007, 01:21 AM   #5
IHateHacks
IHateHacks's Avatar
Hey I build turbo cars too and black smoke=fuel, too much of it I might add. Blue smoke=oil. White smoke=coolant/water.
Kidthunder if I were you, I'd get the ignition timing sorted out first. It is not hard if you know what you are doing. I can post a detailed procedure on how to find TDC and correctly install a CPS, but everytime I give out this info people don't care to use it or don't understand engine dynamics so they just ignore me. Let me know if you wanna correctly set your ignition timing yourself.
Old 03-29-2007, 02:10 AM   #6
IHateHacks
IHateHacks's Avatar
Unless you are blowing clouds of blue smoke under load or WOT, your turbo is fine.
The only thing you can check with the turbo bolted to the engine is axial shaft play. You can check radial shaft play also, but ANY axial shaft play is very bad.
Axial=in and out
Radial= side to side
Old 04-01-2007, 03:38 PM   #7
JunkerMK3gte
Default sry
i was in a hurry to get to the shop. it sounded like it was lamens described. sry about that. on your t/b there is the tps. theres a yellow paint mark from the factory(index mark) the screw and mark should line up. the cam sensor should be about a third of the way up from the bottom of the adjustment slot and last pull off the vacum hose from the pressure regulator, put another on long enough for you to suck on. start the car and suck on it. if you taste gas its bad if the idle changes(listen closely) its good. if not its bad. check that stuff and get back
Old 04-02-2007, 03:26 AM   #8
Reeves
Reeves is on a distinguished road
I have some radial shaft play on my turbo. I believe the oil seals are blown because i get a good amount of blue smoke. It only smokes after I push it then put the clutch in and let it idle, blue smoke will pour out for a bit. There is a lot of oil in the intercooler pipes so im thinking it's pushing oil through into the engine. also no smoke on startup..
What do you guys think?
Reeves is offline   Reply With Quote
Old 04-04-2007, 12:35 AM   #9
JunkerMK3gte
yes, it is the seals/bearings. pull it now and replace/rebuild it before you fry the turbo all together. Garrett turbos has the best of anything you need to do. it costs a bit more, but you wont have to worry about it again.
Old 04-06-2007, 05:46 AM   #10
Reeves
Im just gonna go ahead and get a whole new turbo from turbonetics.. I think all I need is new manifold, injectors, fuel pump, AFM, and all the electronics that go with it. Plus a good tune.. Right? Already have a metal headgasket with ARP headstuds and full 3" exhaust.. I also want to get new hardpipes and a blow off valve.. All this money though.. Don't know where Im gonna get it.
If you guys have any advice, throw it my way im. Im always open to suggestions and have found that in fact, I do not know everything =D.
Error Codes 42 and 43 Getphazed MKIII Supra 6 09-14-2008 10:32 PM
Codes 25,26,51! justin1642 MKIII Supra 11 08-30-2007 08:08 PM
Got Codes? h8z2luze MKIII Supra 14 08-29-2006 01:48 AM
fault codes on a newly re-headed supra lethalwithasupra Non-Generation Specific Questions 5 09-28-2005 08:22 AM
diagnostic codes Alberto O. MKIII Supra 5 07-29-2005 12:50 PM
