Old 03-11-2007, 07:58 PM   #1
ebang
Angry Help!!!
I have a problem getting the oil filter off. It has been 3 hours and I had many people try it...still not coming off....now it is all chewed up...any suggestions please!!! before I start to freak out
1987 N/A Targa 5 speed
no mods as yet
Old 03-11-2007, 08:07 PM   #2
SupraDupra
SupraDupra's Avatar
I never re-use filters so I just stab them with a screwdriver and use that as a handle ,though it does get messy since the oil starts running everywhere. Next time you find yourself at a dollar store check their tool section for a strap wrench. Those work pretty well too ,for many things. Just a rubber strap and a handle.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 03-11-2007, 08:49 PM   #3
jfunez
jfunez's Avatar
since its al chewed up..now u dont have many options...give the screw driver a try, although there isnt much room in there but what the heck......not many options....by the way..next time ..dont overtighten the filter....since it expands with heat and gets tighter...good luck..
Old 03-11-2007, 09:51 PM   #4
A MAJOR problem Toyota (and perhaps some others, too) had in the '80s and early '90s was filter gaskets sticking to the block.
Many engines were destroyed because the mechanic did not make sure the old gasket was removed. Then he put the new filter OVER the old gasket. The pressure would blow out the old gasket, and the engine had a meltdown when it ran out of oil.
One of the main causes of the gasket sticking was that a coating of new oil was not applyed to the filter gasket before installing it to the engine, so it bonded to the block.
So.....try using a small hammer and a chisel. Place the chisel at an angle on the filter base and hammering it to start the filter turning. I've done this with success several times over the years.
Old 03-12-2007, 12:36 AM   #5
ebang
well after about 4 hours finally got it removed...wow!!...thanks for the replys...anyways now that all that is done I noticed that the oil level gage on the dash is staying on "0"..anyone know why?
no mods as yet
Old 03-12-2007, 12:39 AM   #6
jfunez
jfunez's Avatar
you probably accidentaly disconnected the oil pressure sending unit plug while you were messing around with the oil filter.......it should be close in that area, its a single wire connector with a rubber boot on it...
Old 03-13-2007, 03:22 AM   #7
ebang
I will check that but I did notice that it worked fine for a few starts and then today it did not read again.
no mods as yet
Old 03-13-2007, 04:51 AM   #8
plaaya69
plaaya69's Avatar
Cool
Also if you change the oil your self alot I would use the K&N oil filter because it has a fitting on the bottom(almost like a nut welded on the oil filter) so you could just put a scoket and get a wrench and it would come off very easy and it wont be a pita lol.
Old 03-13-2007, 01:54 PM   #9
ebang
well the filter troubles are over, I now have to check why the dash gage does not work all the time. I have a few other questions as well.
1, I replaced the rad with a new one and I notice some smoke from the rad now, It is not leaking anywhere, could this be just because it is new?.
2, whenever I start her up she will rev real high around 1700-1800 and only after about 15 mins come to rev normally around 700-800...is there something I would need to adjust? I don't think it is a cold start issue.
no mods as yet
Old 03-14-2007, 12:50 PM   #10
plaaya69
plaaya69's Avatar
1- The somke could be fine. If it is brand new then it might just be burning off some spilled coolant.
2-check your cold start temp switch. It might be bad.
