Old 03-11-2007, 03:25 AM   #1
mad_dicer
mad_dicer is on a distinguished road
Default question about gas guage
my gas guage does not go above half way on my dash even if i fill it up. but after it gets to under a half tank it will work right and go down as i use full but for some reason it will not go above half way and will not work till i have less then half tank of gas.any ideas on what might be wrong thanks.
mad_dicer is offline   Reply With Quote
Old 03-11-2007, 04:33 AM   #2
mrnickleye
mrnickleye's Avatar
Sending unit in the tank.
Old 03-15-2007, 09:57 AM   #3
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
someone has probly been fiddlin with the fuel sender in the tank, and probly put it in the wrong way so it's getting caught on the tank
make sure the unit is as pictured: (sorry bout the blurry pic)
Pics of my build.
Do a diagnostic first!
Old 03-15-2007, 10:05 AM   #4
Kuban
Kuban is on a distinguished road
wow... ur the only person i know who's on the forums this early in the morning when i am haha. And thats saying alot cause i work third shift and im on break ;P
Kuban is offline   Reply With Quote
Old 03-15-2007, 10:26 AM   #5
suprra_girl
7M POWAH! ;)
lol you're forgetting i'm on the other side of the world and it's currently 11.30pm on thursday
Pics of my build.
Old 03-15-2007, 11:56 PM   #6
Bill UK
AEM EMS
Bill UK's Avatar
Sounds like the sender unit windings need cleaning, It sounds daft but the sender windings become coated in a sticky fuel residue, considering it spends most of its life submersed in fuel you wouldn’t of though that possible. You gain access to the unit by lifting the carpet up in the rear to expose a round galvanised plate secured by 3 cross-headed screws. Before you start! disconnect the battery, (sparks and fuel don’t mix very well apart from inside the engine.) Remove the plate and you will see the top of the fuel tank and the sender unit, before you remove the unit disconnect the plug and match mark the unit so you can fit it back in the same way you removed it. Undo the brass securing screws and lift out the unit, you will now see the coil and wiper that moves across the coil when the float moves up and down. Very carefully clean the coil with alcohol; I used the wife’s nail varnish remover and a cotton bud. Re-fit and hopefully it should be OK. I think the gasket between the unit and tank is made from reusable silicon rubber so you properly want need to buy another one. Uk time Friday 00.02 am
Old 03-16-2007, 12:19 AM   #7
Bill UK
AEM EMS
Bill UK's Avatar
Just had an idea! may be worth adding Red X injector cleaner to the fuel to see if that works first.
Old 03-16-2007, 02:11 AM   #8
OfnaRcR
OfnaRcR is on a distinguished road
Yeah my tank reads empty until about 1/3 tank then its normal.
OfnaRcR is offline   Reply With Quote
Standard boost guage measurments lensosupra MKIII Supra 3 05-06-2008 08:23 AM
fuel pressure guage FullOfProblemsMKIII MKIII Supra 3 01-21-2008 11:52 PM
New here, quick question on possible lean issue adamsbomb MKIII Supra 6 02-13-2007 04:42 PM
boost guage not working! flight doc89 MKIII Supra 0 01-29-2006 07:53 PM
