Old 03-08-2007, 01:33 AM   #1
JMoses
JMoses is on a distinguished road
Default Cam Position Sensor
I just put a new head gasket on a supra that I bought already taken apart. The person who took the head off took off the cam position sensor. I looked in the haynes manual that you have to put the rotary pin in a certain position put it doesn't tell you what position that is. Does anyone know???
JMoses is offline   Reply With Quote
can cam position sensor cause 88Tsupra MKIII Supra 4 03-22-2007 01:25 AM
Idle Position Sensor Problem White87Turbo MKIII Supra 4 06-20-2006 05:38 AM
Cam position sensor and Knock sensor Burn N' Up MKIII Supra 1 11-23-2005 11:27 PM
SUB THROTTLE POSITION SENSOR BYPASS TRICIA93TT MKIV Supra 0 08-26-2005 03:31 AM
