Old 05-25-2007, 12:37 AM   #71
marc
GRRRRR. im about to throw this car out a window....when i start it the rmps jump about 1k and fluxuate liek that...then they continue to do it as i drive...amd omce i hit 2.1k the car dies until the rpms drop and it goes again till 2.1 rpm....and smoke is comming from my exhaust/turbo areas..and smells awkward...i dk if its cause i shimmed my wastegate a couple washers, but im taking them out tommorow and seeing if thats it.
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 05-25-2007, 12:46 AM   #72
marc
when i put my throttle body on there was this thing that looked like it had a cotton ball at the end, it was a black tube..thing. was i supposed to attach it to anything? i mean i just left it like hanging when i attached my throttle body.
its the thing all the way at the bottom dangling down
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 05-25-2007, 01:13 AM   #73
supradaddy0803
supradaddy0803's Avatar
That thing is like a vacuum filter. As for that screw that came out of the fuel pressure regulator or the thing at the end of the fuel rail. That screw is what releases the pressure at the fuel rail so if it is gone then you arent building up any fuel pressure. As for the vacuum lines on your turbo I have a 1JZ the vacuum routing is a little different. Just listen for a hissing around that area and that is were your leak is or spray brake cleaner around on your vacuum lines and if the idle gets better that line has a leak. As for the vacuum filter it doesnt connect to anything just hangs there. Lastly as for throwing it out the window the car weighs like 3400 pounds kinda hard to throw and push and stop.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 05-25-2007, 02:39 AM   #74
IHateHacks
IHateHacks's Avatar
That thing you show in that picture is called a Dashpot. Go look it up in the TSRM. Its there, you just have to look real hard. And yep, it just dangles there with that cotton shit hanging out of it, that shits stock.
Calibrate your TPS. That is why you can't rev higher than 2.1K. Why the hell did you even take your TPS out? Let me guess, to clean the throttle body? Yeah that was worthless and looks like you did more harm than good.
Calibrate your TPS. I can guarantee that is your problem.
And a MK3 supra weighs around 3675 lbs. More like 3700lbs if you have the spare tire.
Old 05-25-2007, 10:09 AM   #75
marc
ok well theres 1 suspected hose i needa replace, and ill calibrate the tps in auto...thank u very much all of u..ill let u know if it works later on today
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 05-25-2007, 10:34 AM   #76
marc
ok i tightened the fpr screw, and i noticed that my fpr isnt holding pressure, its leaking a little gass out at the bottom...could this be the cause of the fuel cut?
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 05-25-2007, 10:59 AM   #77
marc
i lied, its not the fpr, its the thing all the way at the opposite side of the fpr
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 05-25-2007, 12:23 PM   #78
IHateHacks
IHateHacks's Avatar
That would be the fuel pulsation damper. Let me guess, you didn't replace the copper sealing washers?
Fuel is the worst fluid to leak on a car. Not only will it not run right, but you severely increase the risk of having the car burst into flames. Not good. Replace those sealing washers, that car is not road worthy at this point.
Old 05-25-2007, 04:02 PM   #79
marc
i know...ok well update on the fuel cut issue...my teacher seems to believe its my tps...we tried adjustign it but the numbers wuld never match up to wat they were uspposed ot be...he says its always getting current or sumthing liek that, even at idle so the car cant tell when im accelatating or sumthing liek that...so i needa order a new 1
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 05-25-2007, 09:51 PM   #80
marc
i also hear it culd be a leak in the intake manifold??
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
A/C Problem schutz86 MKIII Supra 9 07-20-2008 06:08 PM
Second half of the season begins in Aug… Guest Off Topic Forum 2 07-19-2005 10:53 AM
