Old 02-20-2007, 05:35 PM   #1
Inlinesix
Inlinesix is on a distinguished road
Default Need Major help and bad, no electricity.
i was driving my 1986 3.0 nonturbo supra. was running great. got home, put it in park and turned off the head lights. turned the key once, fron on to acc. and the whole car just died. completly. battery has a 12v charge. but it ain't making to the inside. dash lights, cigar, door lights, key lights for the door and the ignition, nothing. its all dead. checked the fuses and they all seem good. not burt. what do i do, i nned help bad.i'm out of ideas. please help.
Inlinesix is offline   Reply With Quote
Old 02-21-2007, 01:44 AM   #2
volto
volto's Avatar
volto is on a distinguished road
My bro's was doing the same thing. It was a short with his. I think the supras have a safety system where if tehres a short, it shuts off all power. I would take a test light and see what has power and what doesnt. (fuses and relays)
volto is offline   Reply With Quote
Old 02-21-2007, 02:50 AM   #3
mrnickleye
mrnickleye's Avatar
Unhappy
Start looking here.....
http://www.cygnusx1.net/Supra/Librar...ction=D&Page=3
Perhaps the fusible link blew near the battery.
Old 02-21-2007, 03:08 AM   #4
supradaddy0803
supradaddy0803's Avatar
My old 86.5 did the same thing and what it was the negetive battery terminal was cracked and loose and when you turned the key on at first the lights and everything worked then go for a start and everything died and went completely off. It might look fine if it is the factory one just grab on the insulated part and shake if it is loose then tighten or replace.
Old 02-21-2007, 03:21 AM   #5
mrnickleye
mrnickleye's Avatar
Unhappy Battery Neglect
So true.
You would not believe how many vehicles come into the shop for a smog test, or some other work, and we find that the battery terminals are totally wasted. Powdery corrosion all over them.
It is probably the most neglected parts on the car.
New terminals are only a $1 or 2 each.
Use baking soda mixed in warm water to pour and brush onto the battery terminals. It neutralizes the acid. Then use plain water to rinse it all off.
You can get a post and terminal cleaner tool at any parts store.
Those little 'anti-corrosion' felt discs you put under the new terminal work to keep them clean.
Cut the cable back some, and strip the insulation with a knife.
If there is white powdery corrosion in the copper wiring down in the cable, trim it back until its all gone, or replace the cable.
Old 03-01-2007, 04:05 PM   #6
Inlinesix
Default HEY thanx guys.
it was the fusable link. replaced it and it fired right up after adjusting it self. when the power went out it's like the ecu lost it's settings at first. but i just let it warm in to it. and it's all good now.
