Old 02-12-2007, 12:43 AM   #1
jimz
jimz is on a distinguished road
Question 1jz in '87 supra?
Hey Im thinking of buying a 1987 supra off a friend. Its in bad shape and doesn't run. Instead of fixing up the motor i was thinking of swapping in a jdm 1jz twin turbo.
Can this be done?
what would i have to do or buy to get it in there? (mounts, etc.)
and how much would this cost me (not including the motor)?
I'm not the greatest mechanic, how hard would it be to do it?
Thanx alot.
jimz is offline   Reply With Quote
Old 02-12-2007, 04:49 PM   #2
Supra2NR
Supra2NR's Avatar
Well you need the engine first
I believe you need new mount for the engine
I've been told the turbo tranny from a 7m can work with the 1jz but you need a diffrent bellhousing
A 1jz ecu
And you need to extend the wiring harness by 3 feet
Since the 1jz were designed for rhd vehicles
Don't know if you'll need a new drive shaft for it too
Basically I'm gonna tell you what I believe
Is more cost effective
If your willing to get all this to convert a 1jz
You might as well go all the way amd get a 2jzgte engine and then get all the goodies for it
Old 02-13-2007, 03:43 AM   #3
j3pz
doent need a driveshaft if you are getting a bellhousing. pretty much everything else sounds right. however if you arent the best mechanic, dunno if this is the best idea... jmo
Old 02-14-2007, 07:16 PM   #4
jimz
I'm going to try to get up to about 350 horses as cheap as possible. (peferrably under $4000) What would be the best way to do this?
I can get a jdm 1jz for about $1600 with distributor, intake manifold, alternator and both turbos.
or
a Jdm 7mgte for about $1100 with distributor, exhaust manifold, and turbo.
what would be the best way to go? and what would be the mods i would need to get?
Old 02-14-2007, 09:07 PM   #5
damdog05
damdog05's Avatar
i dont have a turbo, but in my understanding, 350 hp is easily attainable with the 7mgte. little or no mods needed to put it in, depending on if the one your buying is turbo or not, and youll be able to find parts for it much more easily than with a 1jz. just make sure the head gasket is in good working order
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
Old 02-15-2007, 05:51 AM   #6
drmmr15
drmmr15 is on a distinguished road
How about $5000?
Reliable horsepower isn't cheap
1987 Supra Turbo
GReddy TT
Open Element Filter (<---not sure what brand)
YAY BOOST!!!!....finally...
drmmr15 is offline   Reply With Quote
Old 02-15-2007, 08:03 AM   #7
mizuboi
mizuboi is on a distinguished road
if you want a good strong turbo taht will easily reach 350 hp then i have one for pretty cheap and it comes with the new exhaust manifold
my modifications
blitz nur spec catback exhaust, JDM 7m-gte, hks head gasket, arp bolts and studs, k&n air filter, Clutch masters FX300, hks SSQ bov, spearco intercooler, NGK iridium plugs
comming:
new fly wheeel
and not running
for sale
car parts for sale
misc. things for sale
stole it from sm
mizuboi is offline   Reply With Quote
