Old 02-04-2007, 07:12 PM   #1
petey turbo
petey turbo is on a distinguished road
Default Coolant temp sensor thread size??
I need to install a coolant temp gauge since I am fed up with trying to get the stock gauge to work. Does anyone know the thread size of the coolant temp sensor for the gauge?? I know there are I think 3 different coolant temp sensors on the tstat housing, but the one I need to know is for the gauge only..
petey turbo is offline   Reply With Quote
Old 02-04-2007, 09:24 PM   #2
Don't know, but it will be a pipe thread size that is tapered.
Old 02-05-2007, 03:00 AM   #3
IHateHacks
IHateHacks's Avatar
It's definitely not pipe thread size or tapered.
It's metric, and not tapered. And any cheap aftermarket temperature gauge will have the metric size adaptor to fit it.
If my memory serves me correct the size is M14 X 1.5
Old 02-06-2007, 04:07 AM   #4
Red face Whoops
You are correct. I was thinking tapered in SAE senders, etc.
Toyota uses aluminum or copper gaskets (although I like to ad some teflon tape or sealant on the threads).
Old 02-06-2007, 10:12 PM   #5
Xanatos
Xanatos is on a distinguished road
Default Coolant temperature sensor
Not to hijack the thread, but I though this might be relevant rather than starting a whole new one.
Is the "radiator cooling fan sensor switch" a simple off/on at a specific temperature, or is it variable? If so, would anyone know what the temperature trip point might be? Reason I ask is I'd like to hook into this circuit as a trip for the relay controlling my electric fan setup. I already have a threaded sensor in the radiator, but I'd like to have a backup on the t-stat housing as I feel the temperature reading there might be more indicative of needing to turn the fan on as opposed to just the one in the radiator. I've tried hooking into the one for the AC Coolant sensor switch as I assumed it functioned the same as my aftermarket one that I installed in the radiator (looks very similar). It is possible that it might not be working just because the sensor could be bad too. Otherwise, I'm thinking about yanking one of those t-stat sensors out and replacing it with an aftermarket one. Where can one find the 14mm x 1.5 to NPT adapters?
Thanks in advance guys and gals.
Xanatos is offline   Reply With Quote
Old 02-12-2007, 06:15 PM   #6
Xanatos
Bump. Anybody?
Funky engine coolant issue shirkinator Non-Generation Specific Questions 1 06-22-2009 08:37 AM
strange temp gauge activity D_Train MKIII Supra 21 08-25-2007 05:43 PM
