Old 02-02-2007, 08:12 PM   #1
Burn N' Up
Burn N' Up's Avatar
Default Spoiler light removal
Any pulled the LED light out of the spoiler? I can't seem to figure out how it's attached and I don't want to break it. Any help would be great, thanks =)
89Turbo 5 speed:Eibach lowered,Tokico Illumina II TEMS,All Poly Bushings,3" Elbow/DP/Cat,HKS Sport Turbo Exhaust,K&N FPIK w/ AEM Dryflow,Cooleeze ceramic coated Turbo inlet Pipe and 2.5" hard IC Pipes,Custom 2.5" fitting Spearco IC,HKS SSQV BOV,Greddy 1.5mm MHG and timing belt,Magnecore Comp Wires,NGK IR Low-temp Plugs,ARP studs,Dual Flex-a-lite fans w/ thermo switch,Fluidyne Rad,PCV VTA,Stage 3 F1 Racing clutch,Stainless braided clutch line and brake lines,Drilled & slotted rotors,EBC pads.
Old 02-11-2007, 11:53 PM   #2
Burn N' Up
Burn N' Up's Avatar
Bump! Help!?
88 supra dome light removal help Jjona5 MKIII Supra 3 09-04-2014 06:10 PM
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
Spoiler Brake Light Info Bill UK MKIII Supra 0 10-27-2006 10:06 PM
Spoiler Removal suhimesu MKIV Supra 1 02-23-2005 02:51 PM
