#1 |
Yea, I was also gioing to get a fuel cut defenser from HKS. Is that good?
#2 |
fuel cutoff is like 10-14 psi
http://www.suprastore.com/19turspec.html Horsepower 230 Torque 245 Weight 3400-3500 Engine 7M-GTE 2954cc Transmission R154 Boost 6.8psi Turbo Toyota CT-26 Spark Plugs NGK BCPR6EP-N8 Injector Size 440cc Compression 8.4:1 Cylinder Pressure 142 Fuel Pressure 33-40psi Fuel Shutoff 11.4-13.7psi Intercooler Efficiency 3psi drop@6.8psi Wheels 16x7 / 225-50-16
Upgrades- 225/50/R16's Kumho ECSTA AST (KU25) 273 bucks with shipping Magnaflow exhaust NO KAT K&N Air Filter www.myspace.com/coreyjstevens http://vids.myspace.com/index.cfm?fu...oid=1536317037 <------ this one should work check out the accident one aswell ya i might be a "fat kid" but i sure can move fast!~ |
#3 |
So that means that between 10-14 psi, the fuel will cut out? Why at that point? Is it some kind of protection?
#4 |
Fuel cut is when the fuel pump can no longer flow enough fuel to supply what the injectors are demanding. Fuel pressure rises about 1 psi for every psi of boost. As fuel pressure rises, flow falls. Yes, I know that doesn't make sense but it is a proven fact. That 10-14psi range is just the general range that a stock fuel pumps' flow falls off. Now when that happens the air/fuel ratio becomes dangerously high and detonation is emminent. Thats when the ECU cuts the fuel entirely to prevent damage. You can raise the fuel cut boost range with mods like a walbro fuel pump, 550cc injectors and a lexus MAF but fuel cut will always be there. It's your engine's way of telling you you need more fuel.
#5 |
okay..So do I have to use the Lexus AFM, or will the VPC be good enough? I will be using it in conjunction with a GCC anyway.
#6 | ||
but then my bov broke, and the car was overboostin nut still i was boostin a steady 10 until my bov got worst never hit fuel cut Quote:
http://www.myspace.com/supra_2nr ![]() Into Bikes now,, apparently the supra couldnt kill me, so my zx6 might lol |
#7 |
hey whats the best injector brand to go with
88turbo targa-white original Pin Stripe custom intake-Tenzo filter.....Momo racing seats and steering wheel... apexi exhaust tip-custom 3" piping. Replaced with RSR GT II NGK plug and wires HID conversion head lights HKS Turbo Timer Type-1 (in black) Tial BOV BIC DDP |
#8 |
You guys sound like you know enough, but there is no need ot fight. I don't have much to spend on this car right now, therefore, when I do something, I like to do it right the first time and not half step. If I use the HKS VPC as an afc, will that be sufficient? Like I said, I don't want to buy something now and in a about a year, by the thing I should have bought when I do my rebuild.
#9 | |
This is incorrect!! Fuel cut is the ECU slowing the fuel injectors to idle, To stop the car from breaking itself. It stops it when the AFM is reading higher than a predetermined frequency. That is why its a general range, because of air temp, humidity, barometric pressure, etc. It is not the fuel pump failing. If you hit fuel cut it feels like you just broke something, and the CEL will come on for a little while. And detonation happens because the inside of the motor is getting so hot when the piston is on the way up it detonates the fuel before the sparkplug does, also not because of fuel. It can detonate because of lean air/fuel, but thats not all that causes it. And not matter how much gas you have, the ecu will still cut it just the same. Its about air! not fuel. But of course they must match. All the lex afm does is let unmetered air go through, and the 550s to make up for it. which is basically a crap shoot with tuning.
Yay the supra assistant is gone!!! WEEE!! |
#10 |
im sure nate knows what he is talking about
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Boost and Stock Fuel | collink | MKIII Supra | 5 | 03-26-2008 11:43 PM |
| How much boost could you run on stock 7mge internals? | supraman121 | MKIII Supra | 2 | 02-22-2007 11:46 PM |
| boost on stock with ct26? | carlosemagana | MKIII Supra | 8 | 12-31-2006 07:48 AM |
| boost on stock motor | john buck | MKIII Supra | 12 | 11-12-2006 08:14 PM |
| stock boost | drgnframe24 | MKIV Supra | 5 | 08-26-2006 04:12 PM |
