Old 05-10-2005, 04:03 PM   #11
roscoa1
roscoa1 is on a distinguished road
Hi
The rattle has been pin-pointed to the rear of the engine, does anyone know what this can be? is it related to valves being a little noisy?
Cheers
Rosco
roscoa1 is offline   Reply With Quote
Old 05-10-2005, 10:13 PM   #12
gabegsxr7718@msn.com
Guest
Posts: n/a
hey, it seems like to me that, you might have rod bearing knock . i hade the same problem with my supra. and the thing with starting problem my supra does the same thing, you can hold key to the on position wait 5 second then it will crank. i dont think its a bad connection, my friend 92 does it also. i hope i helped. also check your engine grounds, if the engine grounds are loose it can also cause the engine to rattle or shake the car as if it had a cam.
Old 05-10-2005, 10:17 PM   #13
Guest
Posts: n/a
Old 05-11-2005, 01:14 AM   #14
monkihead
monkihead's Avatar
it could be a rod knock, or the lifters in the rear cylinders
monique- better off dead
Old 05-18-2005, 02:13 PM   #15
if it's a deepish hollow sounding knock and it's under load.. you most likely have rod knock... the car has been run low on oil at some stage or someone has thrashed it while cold
good luck with the build
if you need anything let us know
