Old 01-14-2007, 03:56 PM   #1
justin1642
justin1642's Avatar
Default manual boost controller!!!!!!!
ok i just bought a a/f ratio guage and boost guage and i am planning on buying a manual boost controller to raise boost to 10 psi. i just want to make sure that it is safe with stock injectors.
my mods:
3in turbo back exhaust (no cats)
cooleeze accordian replacement pipe
blitz bov
cooleeze radiator hard pipe
lexus afm (not on don't have 550 injectors yet)
engine has less than 100k on it since swap
so with all that just want to make sure i can do this with no problems.
thanks
Old 01-14-2007, 07:42 PM   #2
Supra2NR
Supra2NR's Avatar
U should be good with that
U even got more mods than me
All I got is a simple cone air Intake
Still got the stock exhaust piping
Stock ic piping
Stock injectors
But I'm gonna get a full 3 inch turboback exhaust
New pump
And a afc
U should be good for 10 psi with ur mods
Old 01-14-2007, 07:46 PM   #3
justin1642
justin1642's Avatar
ok thanks for the info i'm gonna go get one now
Old 01-16-2007, 07:32 AM   #4
Isphius
Isphius's Avatar
You should be over 10 psi with the 3 inch exhaust and no cats, and if your not, you have a boost leak somewhere. You shouldnt even need a boost controller with that stuff. And your probably pushing your stock injectors at about 12-14 psi. The stocks will run to fuel cut fine, So your limiting factor is going to be fuel cut off untill you get the lex afm/550s in and you probably still wont need a boost controller then. lol.
Old 01-16-2007, 11:29 AM   #5
marc
where did u get that accordian pipe? it looks f-in sick.
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 01-16-2007, 05:54 PM   #6
Isphius
Isphius's Avatar
They are sold by cooleze. They sell a lot of nice turbo supra parts but there so god dam expensive, So i cant afford them.
Old 01-16-2007, 10:01 PM   #7
justin1642
justin1642's Avatar
i got that pipe from cooleeze on ebay it wasn't that bad of a price and i don't have an aftermarket boost guage on yet so i don't know exactly what i'm at.
oh one more thing the engine was swapped in by my friends dad cuz he had a lift so i am wondering if there are a lot of vaccum lines on the bottom of the engine cuz all of them on top are hooked up. thanks
manual boost controller tak2099 MKIII Supra 5 11-23-2009 11:47 PM
Manual Boost Controller and Turbo timmer question ethan12510 MKIII Supra 5 02-20-2008 10:54 PM
ANY ONE EVERY USE A Apexi Boost Controller donutking MKIII Supra 1 10-07-2005 01:58 PM
