Old 01-13-2007, 05:17 AM   #1
kshuping
kshuping is on a distinguished road
Cool Wont Start
I have 87 7mgte, it cranks but wont start. I've run all of the diagnotic tests I can find, but still can't isolate the problem. I replaced the ECU today and tried cranking it again. No luck. I shorted terminals E1 - T, and now my check engine light isn't comming on. I've check all of the fuses I can find, none are blown. When, I short terminal W to body ground, the check engine light comes on. I'm getting the same results with two different computers. If the check engine light doesn't come on, is that a sign that the ECU is not getting power? If so, is there anywhere I can check for a inline fuse that I may be missing?
kshuping is offline   Reply With Quote
Old 01-13-2007, 06:37 AM   #2
89whitedevil
89whitedevil is on a distinguished road
Default no start
did you check for spark fuel at least thats where i would start and then go to the cam pos sensor or the distributor its possible that has failed was the car runing and then quit?
89whitedevil is offline   Reply With Quote
Old 01-13-2007, 08:19 AM   #3
damdog05
damdog05's Avatar
damdog05 is on a distinguished road
im reasonably sure the turbo doesnt have a distributor, so you prolly wont find that. someone with a turbo should confirm that tho
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
damdog05 is offline   Reply With Quote
Old 01-13-2007, 05:05 PM   #4
89whitedevil
Default turbo
right you are right my bad then check the cam position sensor that is where the dist used to be and it had coilpacks so there is more inplay than just those now you need to check the ignition module too make sure its doing its job
thanks damdog for correcting me and the coil packs if more than one usually dont all die together if there is no spark
Old 01-14-2007, 08:25 PM   #5
kshuping
I did a spark test, I have replaced the cam postiion sensor, computer (ECU), the ignition coil pack, the #2 junction box, the main relay and the ignitor. I still not getting spark or fuel. The car was running, when I took it local repair shop. Every since they got their hands on it, it's stopped running. The guy there kept trying to get me to sell it him, cheap. I think he did something to the car intentionally to disable it. I just haven't been able to find what. I'm sure he did something small to disable the car, I've just run out of ideas of where to look.
Old 06-02-2009, 11:55 PM   #6
Dingo007
Dingo007 is on a distinguished road
Default wont start or turnover
so my supra runs if you push start it but wont turn over or start.... changed out the starter and my battery is still reading 12vlts. so what could it be??
Dingo007 is offline   Reply With Quote
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
My car decides when it wants to start carfanatic89 MKIII Supra 16 02-12-2008 07:50 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
