Old 01-10-2007, 06:19 PM   #1
damdog05
damdog05's Avatar
Default replacing speedo cable
im about to replace my speedo cable and i need some help. i tried taking one off a car in a junkyard last month and i had no luck. i couldnt get it through the firewall and that car had the valve covers taken off so there was more room than in mine. is there a way of taking it out without removing the covers?
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
Old 01-10-2007, 07:54 PM   #2
mizuboi
mizuboi is on a distinguished road
not to poke and prod but why are you replacing your spedo cable? and if you do need to change it do you know which part of the speedo cable you need to change? there is different parts to the speedo cable and if it is just the short one that is really easy to fix just unscrew it but if it is the long piece you will have to dissconect it from the tranny then pull it through the firewall but while inside the cabin under your seering wheel because its just easier that way well it was for me and rememnber to use like a screwdriver to wrench out that blasted rubber part in the firewall hope that helps
my modifications
blitz nur spec catback exhaust, JDM 7m-gte, hks head gasket, arp bolts and studs, k&n air filter, Clutch masters FX300, hks SSQ bov, spearco intercooler, NGK iridium plugs
comming:
new fly wheeel
and not running
for sale
car parts for sale
misc. things for sale
stole it from sm
mizuboi is offline   Reply With Quote
Old 01-10-2007, 10:37 PM   #3
damdog05
damdog05's Avatar
yeah, i took my dash out to replace the light a while back and either when i was taking it out or putting it back in, i snapped the needle that goes into the back of the dash. so its the long part that goes through the firewall.
My cars:
Old 01-11-2007, 01:32 AM   #4
mizuboi
if you want just that part i have it =]
my modifications
comming:
new fly wheeel
and not running
for sale
car parts for sale
stole it from sm
Old 01-11-2007, 03:03 AM   #5
damdog05
damdog05's Avatar
ive already got a complete one, i just need to know how to get the old one out. thanks tho.
My cars:
Old 01-11-2007, 03:44 AM   #6
brs86supra
brs86supra is on a distinguished road
its really not that hard replacing it i had to replace my upper and lower speedo cable like 2 times on my third set now. i got so used to it its easier than changing my oil. all i did was removed the gauge cluster, adn then undid the green housing from the white one and then pulled it through the fire wall without removing the valve covers.
brs86supra is offline   Reply With Quote
Old 01-11-2007, 04:56 AM   #7
damdog05
damdog05's Avatar
did you do it from the inside the car or in the engine compartment?
My cars:
Old 01-11-2007, 04:35 PM   #8
brs86supra
i pulled it through the engine compartment. it was really easy'
Speedo cable broke. What next? Busted Knuckles MKIII Supra 5 10-25-2009 06:01 AM
Speedo gauge furia MKIII Supra 1 09-18-2007 08:17 PM
Extra Cable? 808Supra MKIII Supra 1 08-17-2006 08:15 AM
speedo cable cwmart102 Non-Generation Specific Questions 2 03-08-2005 02:01 PM
