Old 12-26-2006, 02:01 AM   #1
gomezmk
Default No high rpm?
I have a problem with my 87 supra that was a na body with a jdm 7mgte installed. For some reason the motor just does not like to rev pass 5,000 rpm, it's just not pulling anymore. I suspect either a bad ecu, or a ignitor. It does it under load and also in neutral(its a 5 speed). I did basically bought everything on ebay to convert it to turbo. The coils ohmed out ok. The afm is ok because I hit fuel cut once and the fuel cut works off the afm. I know for sure I don't have a boost leak. I installed a FCD, I currently running 11 psi.
Old 12-26-2006, 02:12 AM   #2
Isphius
Isphius's Avatar
Check codes!! it is probably a plugged cat though. check that out. Take your oxygen sensor out and drive around and see if its any better.
Old 12-26-2006, 02:23 AM   #3
gomezmk
I have no codes, no cat and why would the oxygen sensor cause anything if the ecu ignores the o2 sensor under wide open throttle.
Old 12-27-2006, 02:13 AM   #4
kwnate
Check your plugs, fuel filter and fuel pump.
Nate
Old 12-27-2006, 01:52 PM   #5
Staceman
Staceman is on a distinguished road
X2, especially the filter / pump.
Staceman is offline   Reply With Quote
Old 12-27-2006, 04:12 PM   #6
justin1642
justin1642's Avatar
if it isn't any of the above possibly the knock sensor that caused power loss and caused my car to run funny before. could be a long shot though. good luck
Old 12-31-2006, 05:35 PM   #7
Isphius
Isphius's Avatar
If you have a clogged cat and you take the o2 sensor out it gives the exhaust an extra place to go. But since you have no cat you can rule out that idea lol. Also check the above mentioned, boost leaks, plugs, wires, air filter, etc. Make a video of the problem if you can. Does the car miss? sputter or shake? or does it just stop revving up like if you dont open the throttle all the way?
Old 01-01-2007, 10:47 PM   #8
gomezmk
I checked all the plugs, coil packs, wires it's all good. It does not miss, it just stops pulling after 5,000 rpm. It does matter whether the motor is in boost or not, it does it also in neutral so that rules out alot of stuff such as ignition wise being faulty or weak. I'm suspecting either an rpm input such as a cps where data at higher speeds is getting corrupted before it inputs to the ecm or the ecm itself being faulty. It seems engine speed input is the source of the problem.
high idle 3.0trd MKIII Supra 4 04-27-2008 03:37 PM
Headlights only work on High Beam - is it a fuse? t4yl0r10 Non-Generation Specific Questions 8 01-18-2008 03:56 PM
Speedometer, High RPM/Speed whine, High HC's 88 N/A ravenmaster MKIII Supra 8 08-13-2006 12:02 AM
