Old 12-14-2006, 06:44 AM   #1
boogum7
boogum7 is on a distinguished road
Post cat question
will i lose horsepower if i run a cat vs running straight pipes?
no need for emissions in idaho by the way.
just wondering which will give me best performance.
stock
boogum7 is offline   Reply With Quote
Old 12-14-2006, 08:24 AM   #2
sd88supra
sd88supra is on a distinguished road
the exhaust will always be more free flowing without a cat but it helps if you have the right size pipe diameter.
sd88supra is offline   Reply With Quote
Old 12-14-2006, 02:56 PM   #3
Supra2NR
Supra2NR's Avatar
no matter what you do
cat = less horsepower
youre lucky u dont have emissions in ur state
Old 12-14-2006, 09:50 PM   #4
supraman121
Im thinking of removing both the upper and lower cat but we have emmissions in North Carolina but its only on 96 cars and up so i dont no if they look at the exhaust at all.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 12-15-2006, 02:17 PM   #5
Staceman
Staceman is on a distinguished road
If you do remove your cats, keep 'em, and anything else that geta switched out. Just in case you move, or the years change for that item like they did in Arizona. You can always bolt 'em up for inspection/emmissions, then swap out once you pass.
Staceman is offline   Reply With Quote
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
