Old 12-09-2006, 12:21 AM   #1
mizuboi
mizuboi is on a distinguished road
Default car won't start!!!!
hey guys i just got power to everything and when i go to start the engine i hear the relay click but no movement from the starter or anything can some one help me its a 87 manual tranny turbo so right now i'm replacing the starter to see if thats the problem
my modifications
blitz nur spec catback exhaust, JDM 7m-gte, hks head gasket, arp bolts and studs, k&n air filter, Clutch masters FX300, hks SSQ bov, spearco intercooler, NGK iridium plugs
comming:
new fly wheeel
and not running
for sale
car parts for sale
misc. things for sale
stole it from sm
mizuboi is offline   Reply With Quote
Old 12-09-2006, 05:51 AM   #2
supraman121
does it have a factory alarm? cause i use to get clicks and everything from the relays and they stopped one day and i replaced most of them find out that some would cost me more then i wanted to spend lol. But in the end i got my alarmed disconnected and that fixed my problem what is was doing was sending a relay to the starter staying dont start.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 12-09-2006, 11:03 AM   #3
mizuboi
it does have the factory alarm and i did lock and unlock the car turning the key twice and it still won't start
my modifications
comming:
new fly wheeel
and not running
for sale
car parts for sale
stole it from sm
Old 12-09-2006, 11:36 AM   #4
supraman121
what i use to have to do was disconnect the alarm if you take the panel off under neath your steering wheel.. on the right side slittly behing the steering wheel you should be able to feel a plug i use to unplug that for a day and usually that was long enof to reset the alarm or try disconnecting the battery for a little bit if it starts after a couple hours its your alarm but dont go just by the battery try the other way to
K&N Air Filter
Old 12-10-2006, 07:38 AM   #5
G-string
G-string's Avatar
G-string is on a distinguished road
may be somthing really simple liek the battery, had the exact same thing happen to me i woudl try to turn it on and everything woudl work deck and i coudl hear a clicking sound but it woudlnt start up i swore up and down its gota be the starter anywyas i got a jump it started right up and then i went and got a new battery
Soo it could just be your battery
to much pizza makes me feal sick
G-string is offline   Reply With Quote
Old 12-11-2006, 10:41 AM   #6
mizuboi
hey can you give a better description on where the alarm is? like if your on your back looking up under the dash towards the console under the steering wheel where is it? and what color is it? and also its not my battery i had it checked and it was good
my modifications
comming:
new fly wheeel
and not running
for sale
car parts for sale
stole it from sm
Old 12-11-2006, 01:05 PM   #7
supraman121
Well is going to be on the left side of the steering wheel... it should be a brown box about the size of a wallet and there is going to be a big white plug in it with alot of wires coming out of that plug you should be able to feel it and or see it.
K&N Air Filter
Old 12-12-2006, 05:48 AM   #8
mizuboi
would this be a reason for no signal getting to my starter? because i know the starter works
my modifications
comming:
new fly wheeel
and not running
for sale
car parts for sale
stole it from sm
Old 12-13-2006, 12:35 AM   #9
motosparky
motosparky is on a distinguished road
I have the infamous starter ghost myself.
I got so fed up I put a hot jumper to the battery then through a heavy gauge push button and to the starter with 12 gauge wire.
Voila... no more issue.
I just have to be careful of valets and car washes if the beast wont start.
I replaced batteries, alarms, by passed the hood and no luck.
Mine is an auto so I was stranded each time until "it" decided to start.
This is the only sure fire technique to get started in a pinch.
Jim
89 N/A Supra
Previous:
90 Turbo
86.5 N/A
85 GT
http://s81.photobucket.com/albums/j2...%20For%20Sale/
motosparky is offline   Reply With Quote
Old 12-13-2006, 10:29 AM   #10
mizuboi
Jim
hey would you like to explain that in a better detail like where the cables ran from what terminal did you connect the jumper from and what kinda heavy guage push button would that be? like a light switch? haha
pictures would be nice too
also as a side note i bypased my alarm and still nothing seems to want to start it sounds like my injectors work but no turnover and spark so... wfhat
my modifications
comming:
new fly wheeel
and not running
for sale
car parts for sale
stole it from sm
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
