#1 |
do some searching on this forum because there has been a lot of talking about engine swaps. if you want more specfics let us know.
#2 |
it should be very straight forward swap...nothing different than the na, just remove and replace.
as far as preventive, i would replace all gaskets including oil pan,cam seals,turbo gaskets and head gasket. I had my head machinned I believe 20 thousands and ended up using a 1.4 mm titan motorsports metal headgasket and arp studs and so far no leaks...thanks to the supra gods..lol |
#3 |
How much boost are you running?
#4 |
the size of the hg depends on how much the head/block are machined
88 N/A w/ 5spd - stock - not running, bhg 87 turbo/targa w/ 5spd- fidanza light weight flywheel, new oem slave cylinder, apexi air filter, no ac and no heat |
#5 |
i asked the same thing like two days ago same year car just mine looks worse lol i was told if manual i was probly going to need a clutch upgrade and they said the computer was compatable but it's an na computer so i think you or i would probly have to get the computer erased and redone at a dyno shop but other then that everything i was told will bullet up engine trains
Upgrades- 225/50/R16's Kumho ECSTA AST (KU25) 273 bucks with shipping Magnaflow exhaust NO KAT K&N Air Filter www.myspace.com/coreyjstevens http://vids.myspace.com/index.cfm?fu...oid=1536317037 <------ this one should work check out the accident one aswell ya i might be a "fat kid" but i sure can move fast!~ |
#6 |
i believe there is a thread in the faq section...
ah haha i was right http://www.toyota-supra.info/forums/...ead.php?t=1212 use the second link
88 N/A w/ 5spd - stock - not running, bhg 87 turbo/targa w/ 5spd- fidanza light weight flywheel, new oem slave cylinder, apexi air filter, no ac and no heat Last edited by j3pz; 11-18-2006 at 08:00 AM. |
| Thread | Thread Starter | Forum | Replies | Last Post |
| 7MGTE to 7MGE | karu | MKIII Supra | 4 | 10-22-2010 07:22 AM |
| 7mge to 7mgte swap | doodah | Non-Generation Specific Questions | 1 | 01-28-2007 06:50 AM |
| 7mge to 7mgte | kallmijonx2 | MKIII Supra | 2 | 10-22-2006 12:55 PM |
| 7mge motor to 7mgte; no motor swap | boogum7 | MKIII Supra | 9 | 12-10-2005 04:19 PM |
| 7mge to 7mgte without swap? | Stuba | MKIII Supra | 1 | 10-18-2005 03:37 AM |
